Suggestion for a mobile phone under Rs.13,000.
Results 1 to 23 of 23
Thread: Suggestion for a mobile phone under Rs.13,000.
  1. #1
    Fluidic design!!! himangshu's Avatar
    Dec 2010
    Tinsukia(Assam)
    Unhappy Suggestion for a mobile phone under Rs.13,000.
    Hi guys returning here after a long time to start a thread for Suggestion of a new mobile phone.
    1. Budget?
    -> Rs.12,000.
    2. Display type and size?
    -> The largest size possible for my budget. Resolution should be good to read small text.
    3. Form Factor? bar, slider, flip?
    -> Any.
    4. Preferred choice of brand?
    -> Nokia, Sony Ericsson and Samsung.
    5. Preferred input method (QWERTY, touchscreen, numpad, touch-n-type).
    -> Any.
    6. What camera option you want? Please specify need for flash, autofocus, front facing camera.
    -> 3.2Mp or higher with Flash and Autofocus.
    7. Preferred operating system? (Android, Symbian, iOS, Windows Phone etc).
    -> Any.
    8. Preferred connectivity options (3G, Wifi etc)Please specify clearly.
    -> 3G.
    9. Preferred applications (Flash, Swype, GPS, etc)?
    -> Flash if possible.
    10. Primary use of handset (multimedia, camera, mails, internet, gaming etc)?
    -> Multimedia, Camera and Internet.
    11. Any specific mobile phones in consideration?
    -> Not yet considered.
    12. Any other info that you want to share
    Build quality should be good and rugged and Battery life should last for atleast 2 days.
    Thanks in advance.
    43 views and no reply??
    Popular Gadget Deals
    ASUS P5K-VM|Intel C2D E7200 2.53 GHz|Kingston 3gb DDR2 800MHz|XFX GT240 1gb|WD 160gb, Seagate 500gb|CM 350W PSU|Zebronics Antibiotic|BenQ G2220HD|Moser Baer DVD-RW|Logitech MX518
  2. #2
    EXIT: DATA Junkyard comp@ddict's Avatar
    Aug 2008
    New Delhi
    Default Re: Suggestion for a mobile phone under Rs.13,000.
    Dell XCD 35 @ 9.5k
  3. #3
    iGoogle guru_urug's Avatar
    Sep 2010
    Mumbai
    Is ur budget 12k(in post) or 13k(in title)?? Please make it clear.
    Also if u can do without cam flash get the LG optimus one. Awesome vfm phone @9k(online)
    else go for the dell phone.
    If u can extend budget to 14k get the galaxy ace a good phone but pathetic battery life, so rooting and installing custom rom may be needed
    Best bet for u wud be to spend 15K and get the motorola Defy. There wud be huge difference in phones below 14.5k and the defy, so if are spending 13k u might as well go tht extra mile.
    Also noted that u want a adobe flash enabled phone. Only the defy supports adobe flash amongst the other phones in ur range.
    There is one more mentionable phone if U are ok wid the spice brand. The spice mi410 @13k has amazing features on paper. As good as a 19k phone. If u are willing to take the risk go for it, and it also supports adobe flash
    AMD Athlon II X4 630 | Asus M5A97 R2.0 | 4 GB DDR3 1333 Corsair | CM Hyper 212 EVO | 1TB WD Blue | 500GB Seagate | SAPPHIRE HD 6850 | NZXT Gamma | Seasonic 500 Watt | Samsung 19" LCD | Google Nexus 4 16GB | Google Nexus 7 16GB
  4. #4
    Sep 2010
    @himangshu - If you are ok with Symbian then I can think of Nokia C6 for 11.8k or Nokia C6-01 for 13.3k or Nokia C5-03 for 8.4k, but that is if you are not too finicky about Android.All the prices are from Univercell.in.
    C6-01 has 8MP with 720p video recording capability.C6 has 5MP with VGA video recording & C5-03 has 5MP but without a flash & they all run on S60v9.4.
    AMD Athlon II X4 635 || Biostar MCP6P3 || 2GB Zion & 2GB Corsair DDR3 1333MHz || Seagate 1TB + Seagate 500GB || XFX HD4650 || FSP Saga II 500W || Zebronics Fantasy || LG W2043T
  5. #5
    Bond, Desi Bond! desiibond's Avatar
    Oct 2007
    Bangalore
    I wouldn't advice C6-01 as it may not get the updates that C7 and N8 may get.
    @OP, if you can up the budget just a bit, check Wildfire:S, Galaxy Ace and Nokia C7.
    Samsung Galaxy S3 running cm10.1 nightly, Samsung Omnia W, Thinkpad T430 (Core i5, 8GB RAM, 160GB SSD, 14" 1600x900,9cell battery). Desktop: AMD Athlon X2 7750 BE, 4GB DDR2, 1TB HDD, 2600XT, 19" LCD
  6. #6
    Sep 2010
    But Symbian doesn't have any versions like Android(2.0, 2.1, 2.2 & so on). C7 & N8 run on Symbian^3 OS which is different from S60. As such Symbian phones don't have extensive 3rd party support which the Androids have..but OP isn't too fussy about OS thats why I suggested those phones.
    Moreover OP's budget is 12k.So shouldn't we recommend him phones under or at that budget? C7 is for 16.4k at Univercell.
    Hey desiibond, does Ace have DivX/Xvid support? If no then can the DivX/Xvid videos be played using 3rd party software in Ace??
  7. #7
    Aug 2008
    New Delhi
    Quote Originally Posted by desiibond View Post
    All Symbian^3 devices are getting the future updates planned. and C6 launched later than these phones AFAIK, no reason for a newer phone not to receive updates.
  8. #8
    Dec 2010
    Tinsukia(Assam)
    Thank you all for your suggestions. I am deciding to get Nokia C6-01 as Adobe Flash is not that important.
  9. #9
    Aug 2008
    New Delhi
    ^^ C6-01 being a SYm^3 device has FlashLite 4, its powerful enough for flash content.
  10. #10
    Dec 2010
    Tinsukia(Assam)
    Is there any Sony Ericsson phone in my budget??
  11. #11
    Sep 2010
    ^^Oops!no idea about SE phones at that budget. All the good phones of SE that I know are all above 20k. May be someone else does in the forum.
  12. #12
    Oct 2007
    Bangalore
    Quote Originally Posted by himangshu View Post
    go for C7 instead. Like I said earlier, C6-01 may not get updates like C7 and the extra 0.3" of display on C7 helps a lot.
  13. #13
    Human Spambot Zangetsu's Avatar
    Jan 2008
    Soul Society
    ^^how much is C7 costs?
    HTC One V | Nikon D3100 | Apple Ipod Touch 4G | SM ES18 | Casio Edifice EX106 | WD My Passport 1 TB | Seagate Backup Plus Slim 500GB
  14. #14
    Alpha Geek Terabyte's Avatar
    Jun 2010
    Mumbai
    ^C7-16k
    AMD Phenom II X4 955BE (Cooler Master Hyper 212+) || Gigabyte 785GMT-USB3 || Sapphire HD7850 2GB GDDR5 ||Corsair 4GB DDR3 RAM || Corsair VX450W || NZXT Gamma || Logitech MX518
    [B]XPERIA U (Stock ICS) (Rooted)[/B]
  15. #15
    Aug 2008
    New Delhi
    ^^ From letsbuy.com using ICICILB code you can get it for 15.5k price.
    A motorola Defy is a better deal, since you'll be getting a Jabra Bluetooth headset and the price after ICICILB discount will be 13.8k, best deal IMO!
  16. #16
    Jul 2008
    Ranchi
    check out se x10 mini pro.....i gt it for 12,400.....its worth it
  17. #17
    sam
    sam is offline
    Forum Moderator
    Jan 2010
    Guwahati
    ^^ bad old mobile. SE dumped it long back.
  18. #18
    Oct 2007
    Bangalore
    Quote Originally Posted by aishwar View Post
    not at all. total junk device with a stale OS.
  19. #19
    Believe Me or Not!!!
    Oct 2010
    GPS Disabled...
    Go for Motorola Defy, it's better than other options (Wildfire S and Galaxy Ace).
    Otherwise consider C6-01. It was released after C7, so I think once the Anna update is available, Nokia will update C6-01 too.
  20. #20
    Right here right now
    Jan 2010
    Chennai
    well hello friends
    i am on a mobile search trip right now and cant figure out which is the better phone out of these 2.
    it would be very good if u can help me out here
    DEALERS AND my friends are suggesting me to keep away from lg product becasue of the quality and they are little wary of lg as they feel it may malfunction sooner or later
    help me out asap
  21. #21
    Sep 2010
    Then how would have LG managed to sell so many units of O1???
  22. #22
    Peak Oil is real! AndroidFan's Avatar
    Feb 2011
    Quote Originally Posted by aditya2696 View Post
    well hello friends
    help me out asap
    You would trust an LG Refrigerator, an LG Washing Machine, an LG TV... but not an LG phone?
    I know, most LG phones were crap in the past. They are trying hard to change... I wouldn't recommend any other LG product. I have seen their horrible resistive touch screen phones... pure garbage...
    But LG Optimus One is good. I am not totally satisfied by its touchscreen response, but its still value for money. And its value has increased exponentially because it was sold in multiple countries and now it has an excellent developer community.
    Cheers!
    Daily Driver -- Galaxy Nexus Cyanogenmod 11 Nightlies
  23. #23
    Apr 2011
    Quote Originally Posted by ssb1551 View Post
    Ya I will also suggest you the same.
    [URL="http://www.satguide.in/androidnavi/"]GPS Navigation for Android[/URL]
  1. Need a phone suggestion - 16k
    By spacescreamer in forum Buying Advice
    Last Post: 20-05-2012, 01:01 AM
  2. Need Suggestion to buy phone
    By lucifer_is_back in forum Buying Advice
    Last Post: 12-11-2010, 02:27 PM
  3. Need Suggestion for a Mobile Phone Under 20K
    By sourav123 in forum Buying Advice
    Last Post: 30-11-2009, 07:59 AM
  4. Replies: 7
    Last Post: 11-09-2008, 12:09 PM
