Results 1 to 22 of 22
Thread: Suggest A Nokia Mobile Below 5k
10-08-2009, 07:34 PM #1
Hi,
I am buyin a mobile 4 my sis, budget is strict below 5k, Dad will not increase the budget, so pls suggest a Nokia mobile below 5k....Requirements :
Good Battery Backup
could play mp3 songs
mem card
which could install softwares and games
which would look pretty good
ThanksPC(Intel Core2 Duo E4500 2.2GHz + Intel D946GZis + Dynet 2GB + 1GB DDR2 + 500GB WD Caviar + 250GB WD My Passport)
10-08-2009, 08:26 PM #2
Re: Suggest A Nokia Mobile Below 5k
If you can add Rs. 500 somehow then get a 5130 XpressMusic.
Or if you don't mind charging battery DAILY (not too good if you listen to lot of music) then get a 7210 Supernova which *might* fit into your budget.
But best is to wait for Nokia 2700 Classic which would come for 4K.http://TheSmallerBang.wordpress.com
eMachines E725 - Intel T4400 @ 2.2GHz, 5GB DDR3 RAM, 160GB Hitachi HDD
10-08-2009, 08:31 PM #3anarchistGuest
Nokia 5130 express music is around 5.2k, its a good music phone.
Value for money
10-08-2009, 09:45 PM #4
Nokia 3110 Classic
Full Specs : http://www.nokia.co.in/find-products...specifications
User Reviews : http://www.mouthshut.com/product-rev...925072856.html
Reference : http://www.fonearena.com/nokia-3110-classic_528.html
11-08-2009, 12:39 AM #5
11-08-2009, 01:01 AM #6Alpha Geek
- Join Date
- Jun 2008
- Location
- 26.6932 n , 88.423 s. Locate me on google maps
- Posts
- 795
If its for your sister then get 7210 , nice looking phone and girls do love it . Should be just shy above 5k(~5100) . Perfect for your requirment.
I am not sure but i think se w305i is well below 5k now . That phone have killer looks and design , you might consider it .
5130 is great phone feature wise but rarely value feature over looks , that why i recommended those phone.
11-08-2009, 11:27 AM #7Right Off the Assembly Line
- Join Date
- Jul 2009
- Posts
- 20
Nokia 7210 is just under 5k better buy 5130 for 5.3 or 5.4 it comes with 1gb card so more vfm
13-08-2009, 03:29 PM #8
thanks friends for suggestions,
pls suggest Sony or Samsung's alsoPC(Intel Core2 Duo E4500 2.2GHz + Intel D946GZis + Dynet 2GB + 1GB DDR2 + 500GB WD Caviar + 250GB WD My Passport)
13-08-2009, 04:04 PM #9
then u can go for samsung metro 3500...good phone with all balanced qualities...2mp
http://www.gsmarena.com/samsung_s3500-2696.phpPhotography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,Tamron 17-50mmf2.8 Lowepro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP, YN603-N3 flash trigger
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Samsung Omnia W with Sony MDR-ED12,Micromax Funbook & Samsung 550P-S05
13-08-2009, 11:19 PM #10Right Off the Assembly Line
- Join Date
- Aug 2009
- Posts
- 2
3110c, old and fat, yet, good enough.
14-08-2009, 10:29 AM #11
Nokia 5130 anyday over the 7210, 3110c or 3500.
Its a no-brainer actually
I blog at www.techans.com and tweet at @nikhilpai (Previously known as nikeel on these forums)
14-08-2009, 05:48 PM #12
I see samsung 3500 better in every way then 5130 just that it dont have a 3.5 jack
SAmsung 3500 have bigger screen 2.2 inch vs 5130 2inch
Better talk time
16million 320x240 screen while 5130 have 256k
qvga recording while 5130 have qcif
http://www.gsmarena.com/compare.php3...&idPhone1=2569Photography Gears -
14-08-2009, 07:25 PM #13
14-08-2009, 08:40 PM #14Right Off the Assembly Line
- Join Date
- Aug 2009
- Posts
- 2
Two reasons, why I won't buy Samsung: OS and phone design.
The OS seems primitive in comparison to the OS of Nokia and SE. The design of the phones aren't great either, who needs a big-ass Samsung logo in the front?
15-08-2009, 12:17 AM #15
I still think samsung look better...price 5385 @ univercellPhotography Gears -
15-08-2009, 12:48 AM #16Alpha Geek
- Join Date
- Jun 2008
- Location
- Posts
- 795
Samsung definitly look better , but the os is really bad.
Also , samsung is legend for its super crap call quality.
15-08-2009, 11:21 AM #17
my dad has samsung guru 1410. awesome keypad but simply pathetic os and the keys for different characters are not same as other phones.
samsung has always had this issue of being the odd one out.http://TheSmallerBang.wordpress.com
15-08-2009, 12:13 PM #18
Hey me too was luking for a phone within this range.....!!
Thnx yaar.....!!
I wud like to go for Nokia 5130 Xpressmusic....!!- Read The Forum RULES First.
- Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
- Before Starting A New Thread Read The STICKY THREADS First
- Before Participating In Bazaar Section Read The BAZAAR RULES
15-08-2009, 12:26 PM #19
Photography Gears -
17-08-2009, 08:23 PM #20Right Off the Assembly Line
- Join Date
- Aug 2009
- Posts
- 6
Nokia 2700 classic
almost same as 5130 in features. Lacks dedicated music keys.
27-08-2009, 04:55 PM #21
2 of my friends are using nokia 5130 n both of them faced de same problem where de phone does not open any pic or vid n says memory full!!! but i think it was a version issue... so make sure u get ur firmware upgraded
16-10-2009, 10:26 AM #22
Thanks for suggestions friends
i went for nokia 7210 supernova, for 5.3k
got an audio booster.
@ Phone Shop
Colaba, MumbaiPC(Intel Core2 Duo E4500 2.2GHz + Intel D946GZis + Dynet 2GB + 1GB DDR2 + 500GB WD Caviar + 250GB WD My Passport)
Please Suggest a NOKIA Mobile Phone below 12K - Urgent Suggestions Reqd.
By mrintech in forum Buying AdviceReplies: 69Last Post: 10-04-2009, 07:14 PM -
Suggest an 'Easy to use' nokia/sony mobile for my Dad
By raksrules in forum Buying AdviceReplies: 12Last Post: 18-02-2009, 09:32 PM -
Can any one suggest a good Nokia Mobile @ 5-6 k
By netguy in forum Buying AdviceReplies: 7Last Post: 15-07-2007, 10:27 PM -
Nokia 9500/SE P900 or Laptop+Normal mobile ? PLease Suggest
By din in forum Laptops and NetbooksReplies: 14Last Post: 17-04-2005, 12:36 PM -
Suggest a Nokia mobile for 7K
By technoteen in forum Buying AdviceReplies: 13Last Post: 07-01-2005, 10:34 PM
LinkBack URL
About LinkBacks
