| Forum |
| Buying Advice Sub-section for Buying Advice queries. |
#1 (permalink) |
zzzzzzzzzz........
it was working perfectly well and still does.. but the problem is dat i had downloaded some new themes for it and then when i opened the themes menu...phone hang ho gaya!!! and it got restarted all by itself... well, then i deleted ALL those themes and it now only has 3 themes (default ones given by nokia)..... i had installed some themes before as well and they were working just fine... i dunno wat went wrong this time... Can anyone explain????????? |
#2 (permalink) |
hey pal,did u used the proper themes,i mean urs being a s40 phone will only support themes with .nth extension,so nxt time check for that,if still the problem persists,may be i can suggest someting more,but 1st be sure to use the right themes(.nth)
Nokia X6 Nokia E5 Dell Inspiron 15"(Dun fu**in really care bout the suffix,does my geeky chores,that's it) a 500 GB (priceless,every bits of it) music repo. Gold Flake,OMR |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Needed: Pdf Reader for Nokia 3110c | crescendo | Mobiles and Tablets | 3 | 16-11-2008 07:41 AM |
| nokia 3110c queries | yogisworld | Mobiles and Tablets | 2 | 07-11-2008 07:42 PM |
| Query about Nokia 3110C | amc888 | Mobiles and Tablets | 2 | 01-10-2008 10:48 PM |
| Query Regarding Nokia 3110C | BBThumbHealer | Mobiles and Tablets | 26 | 24-08-2008 08:59 PM |
| restaring problem in nokia 3110c | midhu | Buying Advice | 1 | 04-01-2008 11:43 PM |
