Old 14-01-2009, 07:53 PM   #1 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
Default Cellphone from 8K to 10K
My sister need another Cell Phone with a good camera (really good one as she has used SE K790i), in the budget 8K-10K. I initially recommended the K810i, but I think it may be too similar to the K790i, and she wants change...
It should be slim, light to carry around and have a good battery life.
What do you guys recommend?
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
"Luck has a peculiar habit of favoring those who don't depend on it."
Liverpool_fan is offline
Old 14-01-2009, 08:14 PM   #2 (permalink)
vista__n00b's Avatar
Default Re: Cellphone from 8K to 10K
If you can extend your budget a bit further then imo you should have a look at SE T700 for 11.5K. It is everything you are looking for and better. Just ask your sis to have a look at it and I can bet that she'll love it
vista__n00b is offline
Old 14-01-2009, 08:31 PM   #3 (permalink)
The G-Axe Effect
gxsaurav's Avatar
Just tell her to keep the K790i.
Graphics & Web Designer - SlideShare
Portfolio & Blog : http://gxsaurav.com
gxsaurav is offline
Old 14-01-2009, 08:51 PM   #4 (permalink)
Bad Advice, since I'll get it
Actually here budget is 8K which she can extend to 10K. Dunno whether extra 1.5K can be extended. Would look into it though.
Last edited by Liverpool_fan; 14-01-2009 at 08:58 PM. Reason: Automerged Doublepost
Old 14-01-2009, 09:53 PM   #5 (permalink)
If the budge cannot be extended then I sincerely do not feel that you'll be able to find a better phone than K790i. That phone *almost* rules the 8k-10k segment and is very difficult to beat. Although another phone you can consider is Samsung U800E.
Old 14-01-2009, 10:13 PM   #6 (permalink)
life is short..be happy
gopi_vbboy's Avatar
i think nothing better than k790i matches for best camera in this range..go for k810i...its good...atleast u can have two same head/battery/accesories/memory n use interchangebly...
gopi_vbboy is offline
Old 14-01-2009, 10:24 PM   #7 (permalink)
I guess I will have to go with K810i or T700 (if budget permits). I don't know much about Samsung.
Isn't there a similar Nokia in this range?
Old 14-01-2009, 11:48 PM   #8 (permalink)
None of the Nokia models below 10K would provide you a 3.2MP cam that your sis is already using. If she can compromise with a 2MP cam then a few models that can be looked at would be 5310 and 5320. N70 ME rules itself out on weight and thickness front. If you think about extending the budget...some very good phones would be E51, N73 and 5620.
BTW if you are thinking about k810i then you are already looking at something around 11K...why not spend just 500 bucks more and get a much cooler looking T700
Old 15-01-2009, 12:06 AM   #9 (permalink)
dOm1naTOr's Avatar
K810i althought sounds similar is lot better in some matters that K790i.
it slimmer and looks cool...and also it got flash support, which 790 lacks. and its priced some 10.5k. Though ull miss EDGE, there is 3G.
Get K810i and peter's acoustics....it simply rocks.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 15-01-2009, 12:22 PM   #10 (permalink)
I'm Back!:D
Coool's Avatar
+1 for k810...
“Whenever i’m sad, i just stop being sad and start being awesome.”
Coool is offline
Old 15-01-2009, 12:38 PM   #11 (permalink)
At Hell's Disq
hellgate's Avatar
if u can xtend ur budget then get either K810i or N73.
i wud prefer N73 over the K810i due to s60 platform.also u wud be getting both EDGE & 3G.
hellgate is offline
Old 15-01-2009, 03:42 PM   #12 (permalink)
Debian Gnu/Linux User
Sathish's Avatar
Go straight to 5320
Pros:
369 MHz processor (higher than past N series
128 MB RAM (80MB for execution! highest in any other mobile plalform)
140MB User Membor
S60 3rd FP2.
3G
Video Call
class 32
EDGE /GPRS
SD memory upto 8 GB..
2MP / QVGA video recording
cons: Battery life only 3 1/2 hours.
Living for Learning & Learning for Living
Sathish is offline
Old 15-01-2009, 05:16 PM   #13 (permalink)
At Hell's Disq
hellgate's Avatar
^^^ 3.5 hrs????
hav used that fone and it has pretty gud battery life.
hellgate is offline
Need Cellphone between 30k and 40k! monkey Mobiles and Tablets 12 02-09-2006 11:11 AM
Help me here plz...with my going-to-be cellphone Digitall Charisma Mobiles and Tablets 2 09-08-2006 02:41 PM
Cellphone: Should I get one? goobimama Mobiles and Tablets 12 17-02-2006 11:49 AM
The Right Cellphone for the job ... megacoolxs Mobiles and Tablets 4 01-10-2005 04:25 AM
Which Cellphone to buy ? arijitraja Buying Advice 8 20-07-2005 01:54 PM
