Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 02-07-2008, 09:50 AM   #1 (permalink)
Linux Learner
PcEnthu's Avatar
Red face Unable to connect Airtel MO from PC
I activated Airtel MO yesterday in my Samsung E450. The internet connection is working in the phone. But when I try to connect to internet from my PC through Bluetooth, the error "PPP Link control protocol was terminated" is displayed. I followed the instructions in the microsoft.com articles for this problem. But the same error is repeating. Is anyone experiencing this problem?
Its better ti keep your mouth shut and be thought as a fool, than to open and clear all doubts - [Source] Comments section of DistroWatch.Com
PcEnthu is offline
Old 02-07-2008, 10:01 AM   #2 (permalink)
Techtree Reviewer
krazzy's Avatar
Default Re: Unable to connect Airtel MO from PC
If there is a bluetooth icon in the system tray in the right, then right click on it, select Dial-up Networking and search for your phone. When your phone is detected click on it. Another dialog will open and ask you to enter the username, password and the number to dial. Leave the first two blank and put *99***# and press Enter. It'll connect automatically.
In your phone select Access Point as airtelgprs.com.
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 02-07-2008, 10:26 AM   #3 (permalink)
evewin89's Avatar
i also used 2 get same error few dayz back with my samsung E-490 "PPP Link control protocol was terminated" but the net works fine when i surf frm my phone,so i talked 2 Airtel CC & within 2
Evil Lives 4ever......
evewin89 is offline
Old 02-07-2008, 11:21 AM   #4 (permalink)
Linux Learner
PcEnthu's Avatar
@Krazzy, Is there any difference between the operations that you have specified from the procedure that I followed:
1. Install Bluetooth drivers in system
2. Add the phone to the Bluetooth devices list and pair PC and phone using a passkey
3. Create a new DUN connection and dial from it.
Anyway I will try your method and get back.
Also, I have configured the GPRS settings in my phone as received from Airtel after activating MO. So I am sure that there is no problem with the MO configuration settings in the phone
@evewin89, I will talk to the CC and see if they can fix this prob.
PcEnthu is offline
Old 24-07-2008, 02:02 PM   #5 (permalink)
Default Re: problem to connect bsnl gprs from laptop in fedora 9
i connect my laptop with the internet through nokia 6230i (bsnl postpaid gprs)in fedora9 environment but pppd is seeing unknown,for that any page is not seen
subhransu123 is offline
unable to connect 192.168.1.1 hansraj QnA (read only) 2 30-12-2007 10:09 PM
Unable to Connect to SQL Server part_time_ch QnA (read only) 2 24-08-2007 12:20 PM
Unable to connect Dvd rom and Dvd writer together. tango_cash Hardware Q&A 2 04-07-2006 08:19 PM
Unable to connect broadband,win 98 Curious Guest Broadband and DTH 4 21-05-2005 11:44 AM
- by bhaskar
- by Soumik
