Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 04-05-2005, 12:38 PM   #1 (permalink)
Default what type of ADSL modem do BSNL DATAONE & AIRTEL BROADBAND?
hi friends,
I want to know what type of ADSL modem do BSNL DATAONE and
AIRTEL BROADBAND use?
Also how much do they cost?
thanks
nitish
nitish is offline
Old 04-05-2005, 12:40 PM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Dataone ADSL modem costs rs. 3k .
Dataone use modem which connects to the LAN/ETHERNET card, where Airtel modem connects to USB port.
drgrudge is offline
Old 04-05-2005, 02:38 PM   #3 (permalink)
errrr no...Airtel also provides modems which connect via LAN/ETHERNET cards. I know cos I have one. Airtel uses Beetel modems. I think the cost is around 2.6K
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 04-05-2005, 02:55 PM   #4 (permalink)
Data Ones ADSL modem is a modem + router + firewall and it costs Rs 2000/- only to its subscribers who want to buy it.
**** happens
pradeep_chauhan is offline
Old 04-05-2005, 03:51 PM   #5 (permalink)
drgrudge's Avatar
Hmm..., icecoolz, in chennai they got only this USB type modem only, many of my friends have them and all of them USB modems. Yet to see a LAN/ETHERNET modem...
drgrudge is offline
Old 04-05-2005, 04:34 PM   #6 (permalink)
Airtel provided me with a USB or Ethernet option. Currently the USB modem I'm using is branded as Beetel but actually it is a Conexant AccessRunner USB ADSL Interface
Costs INR 100 per month rent. Same with their Ethernet option.
Keith
Keith Sebastian is offline
Old 04-05-2005, 04:39 PM   #7 (permalink)
I think if you have the option the ethernet option is a better choce as its more versitile and has no driver problems even in linux also networking options are easy to impliment.
Is there any cost diff between the two options.
**** happens
Old 05-05-2005, 12:02 AM   #8 (permalink)
No price difference with Airtel. Yeah ethernet is better for linux. I went with the USB as it does not need extra power (no clutter) and is small and cute. And Linux will NEVER be my primary OS.
Ethernet modem is just a phone call away in case I need one. Can always swap as I'm renting the modem. Airtel has excellent customer support, never had internet down time ever since I got my connection.
Old 05-05-2005, 01:25 AM   #9 (permalink)
Actually if you've airtel as your ISP then you've a wide range of modems & routers to choose from,Aztec,Beetel,Xavi,Xentrix
Offtopic but this might help many Airtel users.
Airtel Router Firmware & Modem Drivers page: ftp://203.145.183.222/
www.Oobertech.net
digen is offline
Old 05-05-2005, 02:15 AM   #10 (permalink)
@keith .. iam abt to go for airtel broadband .. nd will be purchasing the modem on my own rather than giving away 3k to airtel ppl ...
so which brand...model no .. shud i opt for. ..
the only requirement airtel chap have told me is the availability of RJ11 on the modem ... ethernet or USB ???
grinning_devil is offline
Old 05-05-2005, 05:54 PM   #11 (permalink)
I've got the modem on rent. INR 100 per month. Good option when you're not sure how long you'll stick with one ISP.
Previously I've used Dlink DSL302g and Netgear DG632 modems with Surecom switches (for home LAN) while overseas. Work fine with all aDSL providers. Both excellent modems and cost approx INR 3000 (on direct currency conversion). The Dlink one is a bit tricky when it comes to configuring port forwarding rules. And heats up quite a bit when outside temps are 25C+.
RJ11 is nothing but a technical name for your standard phone jack. All DSL modems have RJ11 port so you can plug in your phone line. RJ45 is the port you require to connect the modem to your PC ethernet card using a standard (non crossed) LAN wire. RJ45 can only be found on the ethernet modem only.
The DSL302g has 1 USB and 1 RJ45. So you can connect 1 PC via USB and another via ethernet RJ45. I had the modem connected to a 4 port switch via RJ45. This makes it possible to connect 4 PC's (3 on the switch, 1 via USB)
Keith
Old 07-05-2005, 07:56 PM   #12 (permalink)
Just Do It
Charley's Avatar
Dataone uses ethernet card, 2000 rs flat on lumpsome. u get a router with an inbuilt firewall in the modem software
Charley is offline
- by bhaskar
- by Soumik
