Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 08-06-2008, 09:22 AM   #1 (permalink)
left this forum longback
praka123's Avatar
Smile BSNL Dataone some sites not accessible? Here is the Solution:-
Many ppl with NIB-I or NIB-II connection are complaining about they are not able to connect to some sites.sometimes it is google,micro$haft etc.
So the Solution is to change the MTU(Maximum Transmission Unit) to 1454 from 1500 or 1492.
In GNU/Linux , you can easily change by editing /etc/ppp/options file or /etc/ppp/peers/dsl-provider to add MTU value.
First try as root ,"ifconfig ppp0 down && ifconfig ppp0 up mtu 1454" to see the change!I was not able to access youtube and all(very slow).now it changed
In window$ ,I have no idea.apart from in cmd , "ipconfig /ALL" will show those values
but I saw this thread ,in broadbandforum :
http://broadbandforum.in/bsnl-broadb...snl-broadband/
^this is the solution for winblow$ users.
praka123 is offline
Old 08-06-2008, 10:00 AM   #2 (permalink)
Default Re: BSNL Dataone some sites not accessible? Here is the Solution:-
Doesnt the MTU value change for people depending upon their connectivity. The best bet would be to find the MTU value ourselves and set it in the router.
Windows 2000/XP users:
Go to Start/ Programs/ Accessories/ Command Prompt and type the following:
ping -f -l 1472 www.google.com
(That is a dash lower case "L," not a dash "1." Also note the spaces in between the sections.)
Linux users:
ping -s 1472 www.google.com
OS X users:
ping -D -s 1472 www.google.com
Linux and OS X commands are case sensitive.
Press Enter. Then reduce 1472 by 10 until you no longer get the "packet needs to be fragmented" error message. Then increase by 1 until you are 1 less away from getting the "packet need to be fragmented" message again.
Add 28 more to this (since you specified ping packet size, not including IP/ICMP header of 28 bytes), and this is your MaxMTU.
Hope this helps
cool_techie_tvm is offline
Old 08-06-2008, 10:35 AM   #3 (permalink)
praka123's Avatar
even I thought like this!but 1454 is the value that works for now.it is some problem with routing with NIB ?
praka123 is offline
Old 08-06-2008, 10:53 AM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
I dont know, yesterday there were problems, I couldnt access PirateBay and Demonoid, and today its fine. Yesterday I was messing with MTU too, but I couldnt get any value which worked for those sites. So just gave it up, then today I reset it to 1500 and they start working... Must be some problem with NIB.
dheeraj_kumar is offline
Old 08-06-2008, 11:02 AM   #5 (permalink)
praka123's Avatar
I am 100% sure that some problem with NIB(routing?).with MTU=1454 it is a good value.
1492 aint enough
praka123 is offline
Old 08-06-2008, 01:19 PM   #6 (permalink)
GaurishSharma.com
gary4gar's Avatar
I wonder why 1492 does not work, as max MTU for Ethernet is 1500
and anything lower than this should work
Information about MTU
http://en.wikipedia.org/wiki/Maximum_transmission_unit
gary4gar is offline
Old 03-05-2009, 12:59 PM   #7 (permalink)
Hi man..
This really solved my problem.. I was really frustrated for last one month not able to figure out how to solve this issue. Can you please send me an email at lukrahul at gmail.com. I want to keep in touch with you. Please.
Thank you very much for the solution.
rahulrajpl is offline
Old 03-05-2009, 02:25 PM   #8 (permalink)
hansraj's Avatar
@cool_techie_tvm
I have found out the mtu for my router and its 1460 as i am also facing the same prob(nib II) but i am unable to find any option in my router for changing the MTU to 1460.
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 03-05-2009, 02:28 PM   #9 (permalink)
Don't mess with me.
sagar.best's Avatar
huh buddy just understand a simple fact where ever there is a NAME BSNL so it's just a waste and nothing else . It is the worst company i have ever seen.
Stuff are cheap but nothing work than what's the use of buying it.
Soon going to buy my first mobile.
Have a PsP atm having fun with it.
sagar.best is offline
Old 15-05-2009, 12:40 PM   #10 (permalink)
Cool Re: BSNL Dataone some sites not accessible? Here is the Solution:-
Another Simple and Easy way
Just Go to FLYPROXY.COM and enter your website like mobango.com, etc.
Works slow but Good....
arvindgr is offline
BSNL Dataone Pro. hsr Software Q&A 1 04-04-2008 08:59 AM
BSNL Dataone Users Only Charley Broadband and DTH 70 19-12-2005 01:58 AM
BSNL Dataone rakhunathan Broadband and DTH 3 01-07-2005 08:35 AM
BSNL Dataone help [lokesh] Broadband and DTH 14 23-05-2005 02:28 PM
BSNL Dataone ? imprince Broadband and DTH 6 06-01-2005 03:26 PM
- by bhaskar
- by Soumik
