Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 09-04-2008, 10:38 PM   #1 (permalink)
Default BSNL Broadband downtimes???
hi friends
I am really fed up with the frequent downtimes(dunno whether i am using the right word). Is there any solution for it or do i have to live with the agony?? Im UL900 Plus
Downtimes = server not found on the explorers with one of the lights which keeps on blinking frequently when i experience a downtime but otherwise when the net is working fyn the light does not blink but instead keeps on glowing
thanx
beanstalk_230 is offline
Old 09-04-2008, 11:14 PM   #2 (permalink)
TooR
alok4best's Avatar
Default Re: BSNL Broadband downtimes???
which lights are u referring to??
If its router's then. from left 1st one shud be stable green(power light).
second shud be stable pink(shows u r connected), 3rd and fourth shud be blinking consistently with green color(showing data transfer)..
if this is proper, then check whether u have configured DNS properly.
I wish !!
alok4best is offline
Old 09-04-2008, 11:52 PM   #3 (permalink)
yep.. i am refferring to my modem
and ya somthing similar to this happens. HOw to avoid the downtime??
What changes should i make to the DNS?
Old 10-04-2008, 08:27 AM   #4 (permalink)
I Always Prefer 1080p
techtronic's Avatar
AFAIK use OpenDNS - when it comes to Name Resolution this is the best
IPs are 208.67.222.222 and 208.67.220.220.
Also do not use a parallel line (another telephone instrument connected to the jack) when using Broadband.Some modems do not support multiple telephone connections from a single line.
techtronic is offline
Old 10-04-2008, 11:14 PM   #5 (permalink)
actually my telefon line which goes into the modem is initially connected to a matrix intercom or should i rather call it pbx which further gives that line to my modem
could it create a downtime problem??
Old 11-04-2008, 12:01 AM   #6 (permalink)
Evolving Rapidly...
confused's Avatar
2 things create problems...
1>clubbing of electrical and telephone wires in same "patti". [due to induced current in telephone wire, conn is corrupted]
2>parallel phone line, before router point.........
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity
"Female sexuality isnt a myth" - what i learnt in my first year at college
confused is offline
Old 12-04-2008, 01:11 AM   #7 (permalink)
TooR
alok4best's Avatar
Actually thats an ADSL splitter, and it wont create a downtime. see if the connection light(2nd from left) stays stable with Pink color, this means u r definitely connected, may be still ur browsing is slow...for faster browsing use the DNS which is mentioned in above posts, and try downloading some file from Internet, check how much speed and consistency u get when downloading something...
If download speed is consistent then its the problem with ur browsing only which only a proper DNS can resolve.
I wish !!
Old 12-04-2008, 06:59 PM   #8 (permalink)
Set the DNS to obtains automatically it will solve the probelm, I experienced the same problem, after doing this i get constantly good browsing speed.
I don’t know everything, but try to Understand Everything
vrnoormd is offline
bsnl broadband needs help chahal63 Software Q&A 2 04-01-2007 09:55 AM
How is BSNL Broadband savithk Broadband and DTH 9 07-11-2006 11:04 AM
BSNL Broadband in FC5 - HOW? src2206 Open Source 1 20-08-2006 09:53 AM
BSNL Broadband Help !!!! dreams Broadband and DTH 7 26-12-2005 07:55 PM
- by bhaskar
- by Soumik
