Originally Posted by slugger
corollary topic
i was told dat i cud acces my router's ctrl panel in d web browser by typin in d comps default IP
but all iget in IE is live search results and in FF
Firefox can't establish a connection to the server at 192.168.1.1.
y so
That's not the way u do it.Turn on the modem when in windows.Do not connect to the net.Goto start menu>connect to>show all connections>local area connection.
Now after double clicking on local area connection select properties in general tab.Again in general tab of the new open window u should see internet protocol(tcp/ip).Select it and click on properties and in the general tab of the new window enter the following affter selecting use the following -
ip address- 192.168.1.67 (U can enter any value after 192.168.1.)
subhnet mask- 255.255.255.0
default gateway- 192.168.1.1
preferred dns server- 192.168.1.1
leave alternate dns server blank
U do not need to be connected to the net to access the modem.But the modem should be turned on.Restart the pc and then enter 192.168.1.1 in the browser after restarting
Default username and password is admin
