Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 02-05-2007, 12:23 AM   #1 (permalink)
Default BSNL : Why ??
I use the BSNL Home 500 plan and so I started downloading stuff from 2:08am till 7:45am... I was sure to disconnect the connection and switch off the router/modem before starting and after ending... but still when i went online to see my data transfer records from dataone.in and then logging on, they considered all that i had downloaded, i mean isn't it free?? They added it to the net usage and not to the sum of night unlimited... even the service records show that i started at 2:08 am and ended at 7:45am then why is it not free?? Is it their mistake and will they correct is later ? Plz Help... i'm not gonna download anything till i get this cleared ...
bazigaar_no_1 is offline
Old 02-05-2007, 03:09 AM   #2 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Default Re: BSNL : Why ??
Even if you download between 2:15-7:45 it gets listed in your Downloads but does not get accounted in the respective download limit
So no worries.Just download
techtronic is offline
Old 02-05-2007, 10:27 AM   #3 (permalink)
but it's not adding up in the "sum of night umlimited" though.... are u sure i should start downloading again ??
Old 02-05-2007, 10:38 AM   #4 (permalink)
eagle_y2j's Avatar
^^ can u post screenshot of your dataone account page ?
Registered LINUX USER #438929
eagle_y2j is offline
Old 02-05-2007, 12:55 PM   #5 (permalink)
thetopcyborg's Avatar
ya, post screenshot...it wud help us in helping u
it gets recorded as data transferred but it shudn't get added up in your bill...have u recvd any bill or its ur 1st month?
thetopcyborg is offline
Old 02-05-2007, 04:52 PM   #6 (permalink)
uhmmm... in the service records, there is a last column for something called "fee" .... what's that ?? plz tell me ..
will post screenshots soon....
Old 03-05-2007, 07:47 PM   #7 (permalink)
Always Questioning?
emailaatif786's Avatar
You can use the DATAONE USAGE TOOL from www.Shaplus.com
It will exclude the Night usage, and also calculate the Bill automatically.
:smile: Love Digit
emailaatif786 is offline
Old 03-05-2007, 08:52 PM   #8 (permalink)
Ishan's Avatar
instead of 2:08 start at 2:30 coz ur pc clock might not match bsnl's!
then stop worrying coz its free...
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 04-05-2007, 04:59 AM   #9 (permalink)
786
RajU
786's Avatar
ok, here you go
after you login click: Service Records,
there you will find: Select the service you want to query
there you will find your plan, select it, click OK, all done...
786 is offline
Old 04-05-2007, 10:57 AM   #10 (permalink)
BSNL is sucks use Airtel connecton unlimited but you have to face with download speed at day , and at night all are happy.
http://www.miraclesoftware.in
Authorized Software Distributor - Online Software Shopping
boosters is offline
Old 05-05-2007, 02:07 AM   #11 (permalink)
Rockstar11's Avatar
I use the BSNL HOME 1000,
384 Kbps/Upto 2Mbps ( 210 KBPS DL speed)
hmm..... yaar main bhi yahi hi jaan na chahta hoon..
how to calculate my Night Unlimited usage ?
image link >
http://img259.imageshack.us/img259/5...dataoneam2.jpg
plz help
thanks
Rockstar11 is online now
Old 06-05-2007, 12:22 AM   #12 (permalink)
webgenius's Avatar
use a tool called shaplus bandwidth finder to get detailed results of your usage, both in normal time and free time.
webgenius is offline
Bsnl Gprs gmanog Mobiles and Tablets 17 11-03-2007 10:00 AM
Bsnl Help Suhas M Broadband and DTH 2 02-02-2007 07:58 AM
Bsnl vatsav Software Q&A 4 06-12-2006 11:27 PM
- by bhaskar
- by Soumik
