Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 18-03-2007, 08:05 PM   #1 (permalink)
Resident Fanatic
Manshahia's Avatar
Default Broadband Connecting error...
Guys i changed some settings in order to connect to internet in linux...
after that when i tried to connect in windows, it says.. Connecting WAN Miniport and then redials...
Then i resetted the modem from backside but same problem persistes...
I want to knw if there some settings to be done in order to get a reseted modem working...
I wud b very thankful to you, if u can help...
I m dying plz help...
Manshahia is offline
Old 18-03-2007, 08:44 PM   #2 (permalink)
24online's Avatar
Arrow Re: Broadband Connecting error...
check linking light...
check driver/hardware...
proper address (config.) IP/dns/gateway/subnet mask
restart pc with modem...
if not, delete old setup & install new modem setup in pc...
if not, goto http://broadbandforum.in/ & find solution...
**#(o)#**
24online is offline
Old 18-03-2007, 09:34 PM   #3 (permalink)
Resident Fanatic
Manshahia's Avatar
Default Re: Broadband Connecting error...
problem solved...
had to select Bridge mode instead of PPPoe or watever it is...
I m very HAPPY
- by bhaskar
- by Soumik
