Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 17-11-2006, 04:29 PM   #1 (permalink)
shyamno's Avatar
Default How to Port forward on Cable Broadband..
Guys..
Please help me in giving a tutorial on Port forwarding with my cable Broadband (256 kbps)...
I do not get sufficient speed with my torrent clients... usually get around 10-13 KB/s..
I donot know is there any router in my line or not.... they (cable connectors) had put only a ethernet jack in my ethernet slot...there is no other connection ....
I asked them about the router ip address and they had given me 172.16.0.1 but it asks me a user/password...........Later when i asked them to give the user/pass they denied telling that they can't give them....
Please help.!!!!
shyamno is offline
Old 23-11-2006, 12:51 AM   #2 (permalink)
clmlbx's Avatar
Smile Re: How to Port forward on Cable Broadband..
ur isp ?
is it router ( model no ? )
clmlbx is offline
Old 26-11-2006, 05:34 PM   #3 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: How to Port forward on Cable Broadband..
i doubt cable net wala use routers...and i dunno how to forward port w/o router...
An i guess this wrong section if ur not giving any TUTS urself...or if u expect a tut then there is STICKY in thi section use that....
wizrulz is offline
Old 03-12-2006, 08:01 PM   #4 (permalink)
yrana2002's Avatar
Port forwarding is done only via routers, those routers that you can configure by yourself.
Cable ISPs dont offer routers i suppose, so there's nothing you can do much except enable some options like NAT, DHT or use a good port from 45000-60000 and try your luck.
Try changing these settings. Sometimes they do work. You may also change max. number of connections per task and check which setting is the best for you.
Savvy
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
- by bhaskar
- by Soumik
