Results 1 to 14 of 14
  1. #1
    Right Off the Assembly Line Tobuscus's Avatar
    May 2012
    Kochi, Kerala
    Default Best Unlimited Broadband Plan under 1k?
    Hey,everybody
    I'm using the BSNL 900 UDL plan (4mbps until 8 gb,256 kbps after that). And it's awesome for the first few days of the month...i.e youtube in 720p with no buffering and 400 kb/s stable download speeds
    But after i use up my 8 gb,it's a different story....that is,youtube in 240p and 40 kb/s download speed
    I've heard a lot of people say the 750 plan is much better than this one...Could anybody tell me it's avg download speed? How good is it for gaming?
    So basically, I need a plan which is fast,unlimited & good for gaming under 1k
    or the closest thing you know...
    May the force be with you.
    Peace is a lie, there is only passion.Through passion, I gain strength.Through strength, I gain power.Through power, I gain victory.Through victory, my chains are broken.
    The Force shall free me. (Sith Code)
  2. #2
    Wise Old Owl Rockstar11's Avatar
    Jul 2006
    India
    Default Re: Best Unlimited Broadband Plan under 1k?
    Sony HX20V 20x optical zoom
  3. #3
    May 2012
    Kochi, Kerala
    Quote Originally Posted by Rockstar11 View Post
    Thanks.But that's not really what i'm looking for.All those service providers don't operate in kerala,we only have Airtel & BSNL.
    I'm just looking for advice on what bsnl plan to choose?
  4. #4
    Jul 2006
    India
    Quote Originally Posted by Tobuscus View Post
    okkk so go for BSNL 750 UL plan.
    download speed is 60 KBps
  5. #5
    Alpha Geek funskar's Avatar
    Sep 2011
    India
    Better to gor for bsnl 850 bb ul plan
    2mbps upto 8gb afterwards 512kbps and that too wid 180call free
    ||i5-2500K|Ga Z68xp-Ud4|Ripwas X 8gb|Vx550|Seagate 1Tb+500Gb+250gb|Asus Xonar Dx 7.1|Logitech Z906|Xbox 360 Controller|Haf 922|Ps3|No Gpu
  6. #6
    Rusted... dashing.sujay's Avatar
    Nov 2009
    Bhopal
    Airtel 999 plan. Speed - 1 mbps till 75 GB. I guess that enough. This plan is not available openly though, ask your "agent" about it.
    FAQ + answers for new members (Read before asking / messaging any moderator for any query)
    Drop Box: Get 500MB free
    Quote Originally Posted by axes2t2 View Post
    Before working on a master piece you have to first master the pieces.
    Sony Vaio CB35 Asus U32U ATH M20 Fiio E6
    Sony Vaio CB35 UnBoxing & Review
    How fast can you type?
  7. #7
    Wise Old Owl sriharsha_madineni's Avatar
    Jul 2006
    Anantapur / Vellore
    Thanks to a port side bug at our telephone exchange, I get unlimited 1mbps for 750UL plan. Even after the 6GB limit is crossed, I still get 1mbps
  8. #8
    Human Spambot saswat23's Avatar
    Jan 2011
    Bhubaneswar
    But 900 ULD gives 4Mbps upto 8GB and after that 512 Kbps Unlimited. How do you ger 256 Kbps?
    Yup, many are getting 1Mbps Unlimited on 750 ULD. Anyone else who is getting such speed?
    Check here
    My Blog :D
  9. #9
    May 2012
    Kochi, Kerala
    Quote Originally Posted by saswat23 View Post
    I do get 60 kbps sometimes,if i'm using steam ( I didn't know BSNL upgraded their plans)...But that's still not fast enough for 360p video.....
    I'm not so sure about that fup bug on the 750 plan tho. With my luck,bsnl will probably fix the bug the same day i switch to it.
    Anyway,thanks guys
    Hope we'll be able to stream 360p video by the time 8k video youtube is available in other countries....
  10. #10
    Broken In y2j826's Avatar
    Nov 2006
    India
    Sometimes FUP don't work for BSNL and even after limitation speed is 1 Mbps for me too...
    http://worldofy2j.blogspot.com
  11. #11
    sam
    sam is offline
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    when you switch modem off or restart it, FUP gets applied.
  12. #12
    Jul 2006
    Anantapur / Vellore
    Quote Originally Posted by Sam View Post
    Happened multiple times, no FUP applied
  13. #13
    hsr
    hsr is offline
    Green Man hsr's Avatar
    Feb 2007
    Cave
    hey, I am from Kochi too, and I say use BSNL's Home Combo 900ULD, best one out there. Period.
    If you are in a situation you can't apply for a phone, use Asianet's Rapid 899, it gives 900kbps to 25gb and 512kbps beyond. If you have digital cable as well, it converts to 1mbps toll 30gb and 700kbps beyond.
    I have both Asianet and BSNL connections, the better pings are on Asianet's side. Plus their customer service is much better than BSNL's crapfest.
    There is also the BBG Combo ULD 1350 from BSNL, 4mbps upto 20gb, 512kbps beyond.
    Asianet Plans
    BSNL plans #1
    BSNL plans#2
    they have fixed it buddy, they have...
    ٩(ಠ_ಠ)۶
    Rules & FAQs exist for a reason. Read them.
    Bans available at #digit IRC channel.
  14. #14
    Sony " VA" "IO" kARTechnology's Avatar
    May 2012
    I'm beside of my neibour's house, in my house, which is on Eath in Solar System in Milky Way Galaxy
    Quote Originally Posted by hsr View Post
    Asianet Plans
    BSNL plans #1
    BSNL plans#2
    im using BBG Combo ULD 1350 from BSNL, 4mbps upto 20gb, 512kbps beyond.
    its gooood
    GIGABYTE GA-MA78GM-S2HP | TRANSCEND DDR2 1GB MICRON DDR2 2GB | AMD Athlon 4600+ | CORSAIR CX430V2 | VIEWSONIC VA1918wm 19" LCD | NUMERIC 600 Ex-C UPS | INTEX 2000Watt 2.1 SPEAKERS | LOGITECH Media Keyboard | PIONEER VSX-916 | MISSION SATELLITES | DAINTY SUBWOOFER | AIRTEL HD DTH| SONY BRAVIA BX300 | VAIO VGN-CS17G | SONY ERICSSON XPERIA X10 | CYBERSHOT T70 | PLAYSTATION 2 | HANDYCAM DCR-TRV460E
  1. Replies: 5
    Last Post: 01-06-2011, 11:43 AM
  2. Broadband Plan Unlimited...
    By Zangetsu in forum Networking
    Last Post: 03-02-2011, 01:51 PM
  3. Replies: 6
    Last Post: 03-07-2010, 11:13 PM
  4. Share BSNL Broadband Home Unlimited 750 plan?
    By ashnu_tnj in forum Broadband and DTH
    Last Post: 29-01-2009, 10:14 PM
  5. Replies: 105
    Last Post: 20-05-2008, 04:50 PM
