Results 1 to 8 of 8
Thread: BSNL change of plan query
30-06-2012, 12:27 AM #1Apprentice
- Join Date
- Jul 2011
- Posts
- 86
Suppose I have the Home500 plan with 1.5GB usage at day and I have exceeded the usage and extra charges are applicable.
So, if I know change my plan to unlimited 750 before the end of month, do I still have to pay those extra charges for the usage beyond 1.5GB or only the new amount of the plan i.e 750?
30-06-2012, 07:26 AM #2
Re: BSNL change of plan query
Most likely u'll have to pay the extra charges plus the deposit of 750 in ur next bill if u are changing the plan at the end of thr month...even i.had to do so when i changed my plan from 750 to 900 on or around 23rd of the month...and the plan was activated from the 1st of next month..
30-06-2012, 08:15 AM #3
I think you have to pay the bills of this month like you normally do. And your plan will change next month.
30-06-2012, 08:51 AM #4
Yes you have to pay.
Suppose if you use 500 plan for 15days and 750 plan the next 15 days, the bill will be so that 500 plan for 15 days+50% of 750 plan charges(since it is unlimited)..
P.S: For plan change you have claim it in written at any bsnl exchange with your landline no.i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
30-06-2012, 12:58 PM #5
30-06-2012, 02:01 PM #6
^^I've tried that, never worked for me..
30-06-2012, 08:17 PM #7
^^ I wonder how that worked for me in the first go !
Initially had 750 plan as soon as I changed my plan from the portal, the speed increased from 512 kbps to 2mbps and later next month it became normal 4mbps.Founder: Atumaharaj.com
Current Rig: Intel i5-760 3.0 GHz | Gigabyte H55M-S2 | Transcend 4GB DDR3 1333MHz | Sapphire HD 6670 1 GB DDR5 | WD 500 GB | CoolerMaster Elite 431 - Transparent Side Window
Old Experiment Rig: Intel P4 1.6 Ghz | Intel 945 | Hynix 1.2 GB 1333 MHz | Nvidia 6200 256 MB | Samsung 40 GB
Other Stuff: Samsung Galaxy 5670 | Seagate 500 GB USB 2.0 | HP Mini
30-06-2012, 11:51 PM #8
just go to ur nearest bsnl customer service centre and give a request in the prescribed form. ur next bill will carry the new plan charges from the day it was implemented (usually 24 -48 hrs with in request ) and the previous plan charges for the preceding days of the month .
also note that the security deposit(one month charges) is higher for higher tariff scheme , so that difference amt will also be levied in the next bill .Intel Core i5 2400 | Intel DH67BL - B3 | Corsair Value 8 GB | MSi HD 6850 Cyclone PE OC | Seagate Barracuda 500 GB 7200.12 | LG 22x SATA | CM Elite 430 Black w/o TP | Antec Earthwatts Green EA 650 PSU | LG Flatron E2260 | Microsoft Wired Combo 600 | Microsoft XBOX 360 Wired Controller for PC | Creative 5.1
Query regarding Bsnl broadband "BBG FN Combo 600" plan
By digit.sh in forum Broadband and DTHReplies: 8Last Post: 03-02-2012, 10:48 PM -
information regarding plan change BSNL
By ay_aceoo7 in forum Broadband and DTHReplies: 1Last Post: 22-11-2011, 12:32 PM -
Problem with plan change on bsnl
By Dibya9999 in forum Broadband and DTHReplies: 6Last Post: 01-06-2010, 08:04 AM -
Guide : BSNL BroadBand Plan Change For Beginners
By VarDOS in forum TutorialsReplies: 5Last Post: 26-11-2009, 05:34 PM -
Query about BSNL Home 500C plan
By GeekyBoy in forum Broadband and DTHReplies: 6Last Post: 14-05-2008, 05:58 PM
LinkBack URL
About LinkBacks
