Results 1 to 29 of 29
  1. #1
    Alpha Geek koolent's Avatar
    Oct 2010
    Rawatbhata, Kota, Rajasthan
    Question Speed problem with BSNL Unlimited Broadband @Rs. 750 ...
    Hi, I have a BSNL Broadband with teracom modem and unlimited plan..
    I have very low speeds here in:
    Rawatbhata(Via-Kota), Rajasthan, India
    The download speed is abt 20 kbps - 35 KBPS MAX..
    AND
    Upload Speed is 50 KBPS MAX
    I think that is nt enough for broadband.. How can I fix it ??
    Intel Core 2 Duo @ 2.8 GHz, Corsair CX430 v2, 3 GB DDR 2 RAM, MSI R6770 MD1GD5 (finally), MSI MS-7525 (v1.0), Compaq W185q 1366 X 768 HD LED Monitor
  2. #2
    Broken In y2j826's Avatar
    Nov 2006
    India
    Default Re: Speed problem with BSNL Unlimited Broadband @Rs. 750 ...
    All the Unlimited plans are upgraded from feb 1, 2010 therefore there are some technical issues with the new plans in upgradation, it may start working fine after some days...
    http://worldofy2j.blogspot.com
  3. #3
    Oct 2010
    Thumbs down Re: Speed problem with BSNL Unlimited Broadband @Rs. 750 ...
    It has been this way from the day I got it..
  4. #4
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    these speeds are on torrents i am sure?
    go to speedtest.net test speeds there and.post them here
  5. #5
    Human Spambot MegaMind's Avatar
    Nov 2010
    Perambalur, TN
    A BB connec. with 256Kbps will have download speeds of ~30 Kbps & ~60Kbps for a 512Kbps connec.
    With BSNL Unlimited Broadband 750, you'll have download speeds abt. 120Kbps till 6GB of download & after that it reduces to 60Kbps..
    i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
  6. #6
    Oct 2010
    Download spd = 0.05 MBPS
    UPLOAD SPD = 0.07
    PING = 1580 ms
    UPLOAD SPD = 0.07
    PING = 1580 ms
  7. #7
    Fragholic
    Sep 2011
    Goa
    .05 MBPS for 750 plan is around the actual speed you are supposed to get.
    Intelli 3.0 + Qck Heavy + Logitech g510 + AD700 + Xonar Dx + 560 Ti Hawk Edition
    PS3 320GB Move
    Galaxy S2
  8. #8
    Nov 2010
    Perambalur, TN
    Quote Originally Posted by sukant View Post
    OP should get 0.5Mbps not 0.05..
    @koolent, i have the same plan ULD750 this is my BB speed after exceeding 6GB usage..
  9. #9
    Nov 2008
    Guwahati
    koolent there is something wrong with your line
    100% sure. get it fixed. even i had speed like this. became normal after line was fixed
  10. #10
    Oct 2010
    Thumbs up Re: Speed problem with BSNL Unlimited Broadband @Rs. 750 ...
    Right, I also hink so.. I'll surely give it a try.. And thnx..
  11. #11
    Nov 2008
    Guwahati
    No prob
    Report back here when the line is fixed
  12. #12
    Oct 2010
    Hmm.. I'll surely do it..
    Well, techfreak.. Are u using BSNL Brdbnd ?
  13. #13
    Oct 2010
    Yippee.. I don't know what happened but anything which happened is really sweet his is the result now:
    [IMG][/IMG]
    Its also exeeded 6 GB..
    This is pingtest.net result.
  14. #14
    Still a lot to learn
    Feb 2012
    Rawatbhata, Rajasthan
    I also have the same problem. I live near him. My cousin lives about 2 km away with the same plan but still he is getting download speeds upto 190 kbps.
  15. #15
    Oct 2010
    You guys have magic.. These are my download speeds now..
    and pingtest.net ping:
  16. #16
    Oct 2010
    Noo... The speeds are back to where they were:
    What shud I do ? My speeds shot up and are agn down. Is there seriously anything wrong with my line..?? The speeds were up for abt 5-6 days.. Shud I talk to the BSNL Guy or shud I go to the exchange office ?
  17. #17
    Nov 2007
    Bangalore
    Change the mode from ADSL2+ to G.DMT in your router's configuration page, also check SNR/Attenuation.
  18. #18
    Apr 2011
    try changing your DNS server . even me i had a shitty speed before i changed my changed my DNS server since BSNL server are **** or its that they just dont care.
    Am posting two results of the two DNS server am using :
    juts letting you know that before changing my DNS i use to get download speed of around .34 mb/s
    my plan is BB Home Combo UL 750
  19. #19
    Oct 2010
    Where can I change my DNS Server ? Mu plan is also UL 750
  20. #20
    Wahahaha~! Faun's Avatar
    Dec 2006
    Pune/there
    How changing DNS will increase speed ?
    Steam | Flickr | Battlelog
    Asus Z68 V-Pro|i5 2500k|TRUE Black|Ripjaws X|U2311H|N560GTX Ti|D7000|Classic Vibe 50 Strat|XONAR STX|RE272|UM Miracle|Optimus G
    Oct 2010
    AAArgh.. Sugest me something good then plzz..
  22. #22
    Apr 2011
    Quote Originally Posted by koolent View Post
    READ THIS :
    DNS Addressing - How to Change in Windows 7 - Windows 7 Forums
    FOR BEST DNS :
    namebench - Open-source DNS Benchmark Utility - Google Project Hosting
  23. #23
    Oct 2010
    Hey, my upload speeds are much more than download ones.. So, what shud I do other than Changing the DNS ?
    My current status:
  24. #24
    Project Halcyon V2.1 tkin's Avatar
    Aug 2008
    Hyderabad, India
    Are you using Win 7? Run this command in command prompt(admin privilege), it won't help probably, but doesn't hurt to try.
    netsh interface tcp set global autotuning=disabled
    2600k/Z68VPro/Vengeance/U12PSE2/TX750v2/1TB.Black/DRWB5ST/HAF912+A
    M35/PortaPro/E30/Optimus.L9/Siberia/5800XM/FZ150/SH14/FiiO.E6
    Dell.15R/Ci3.3110m/7670m/ALVS4621/Funbook/Ferox
  25. #25
    Oct 2010
    AArgh.. It doesn't do anything
  26. #26
    Game & anime Lover pkkumarcool's Avatar
    Sep 2010
    Florence
    contact ur local bsnl office it is a wireline problem surely..they will fix the issue..
    On TDF after a loooo...nng time!
  27. #27
    Oct 2010
    Thanx guzz.. You guyz really helped me.. M neighbours are experiancing the same problems.. However one of my neighbours is having a speed of 50 kbps..
    My dad has requested the office to send that person who will correct the problem..
  28. #28
    Apr 2012
    Smile Re: Speed problem with BSNL Unlimited Broadband @Rs. 750 ...
    hey koolent. I would be coming to rawatbhata for my summer internship.could you please tell me that which internet service providers in rawatbhata provide broadband facility?i would very grateful to u.
  29. #29
    May 2012
    HI All,
    I recently took BSNL EVDO internet connection that promises 3.1 Mbps speed.Not getting enough speed in torrentz.In torrentz client getting speed maximum download speed upto 150 Kbps.Have tried many web sites for testing internet speed online.
    These are the details
    Ping 274 ms
    Download speed 0 .77 Mbps
    upload speed 0.13 Mbps
    some sites I got result
    download speed 861 Kbps
    upload speed 106 Kbps
    Is this normal.In the websites that check internet speed online should it display 1/8 of the actual speed or 3.1 Mbps.I am not knowing.Kindly help.Is there a problem here?
    [IMG][/IMG]
    AND
  1. Very slow BSNL night unlimited broadband speed?
    By Patriot in forum Software Q&A
    Last Post: 19-11-2009, 09:33 PM
  2. Replies: 2
    Last Post: 28-09-2009, 10:21 PM
  3. Share BSNL Broadband Home Unlimited 750 plan?
    By ashnu_tnj in forum Broadband and DTH
    Last Post: 29-01-2009, 10:14 PM
  4. BSNL Unlimited broadband
    By techx in forum Chit-Chat
    Last Post: 21-05-2008, 04:06 AM
  5. Replies: 3
    Last Post: 03-04-2007, 01:35 AM
