Originally Posted by quicky008
I am a subscriber of BSNL's dataone broadband service.Unfortunately,my internet connection has been acting up a lot for the past few days.I get disconnected every now and then due to incessant link failures.BSNL's technicians have already examined my telephone line several times but couldn't determine the cause of this problem-they've said that nothing's wrong with it.Is it possible that my modem itself is malfunctioning?How can i check whether my modem is functioning properly or not?Here's a screenshot of my modem's config page:
http://i.imgur.com/Wj2Px.jpg
I am using a Siemens c2110 adsl modem.Can anyone suggest how this problem can be resolved?Thanks
There is a problem in your line.
your SNR(downstream) and upstream are very low.
contact SDO and ask him to check your line for noise.
also pick up your telephone receiver and check for distortion.
the line is proper only when these valus are above 20dB.
also set your connection standard to ADSL 2+/ADSL.
here you can find my modem stats for reference.
