Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 05-02-2012, 01:35 AM   #1 (permalink)
Default gaming on wireless network... how??
Following is the main requirement:
I want to connect to my friend's computer (in my society) who is also using wireless Dlink router mainly to play games and share files.
I have checked using a laptop, my friend's wireless signal is reachable @ my place.
is it possible to play games on this wireless network.
if yes, 1. then which router should i go for ?
2. can this router also server for my wireless broadband ?
Or shoud i only go for wireless receiver?
I have Hathway Broadband internet @ home
Alive_Hunter is offline   Reply With Quote
Old 06-02-2012, 09:25 AM   #2 (permalink)
Gamer
Default Re: gaming on wireless network... how??
Depends on the signal quality.
Gaming Rig:
AMD Phenom II X6 1075T @ 3Ghz | ASUS M5A97 | Sapphire HD6850 1GB | Corsair CX500V2 | G.Skill RipjawsX 4GB @ 1600Mhz | WD Caviar Blue 500GB | ASUS DRW-24B3ST | Dell IN2030M | Logitech MX518 | Cooler Master Elite 311
ArjunKiller is offline   Reply With Quote
Old 06-02-2012, 12:19 PM   #3 (permalink)
I already gave you a hint. But you made a new thread again of same.-/ nvm
-Both you and your friend need to be on same router or router cum modem to play over LAN. If you are planing to buy new router then look for wifi n router cum modem from dlink, net gear or Cisco(your pick). Now as you said you are using laptop, so you don't need wifi adapter. But if it doesn't have wifi n adapter then save money and get wifi g router cum modem. Ask your friend before buying router, if he got wifi n adapter then get a wifi n router cum modem and let him join your network instead. Otherwise stick with g standard.
P.S: if you dont have strong enough signal then your pings may increase when you put certain amount of stress on your wifi network, while working, playing, transferring files or any other heavy data usage activity or even worse 'disconnections'.
OSxSnowLeopard is offline   Reply With Quote
- by bhaskar
- by Soumik
