Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 07-09-2005, 11:50 PM   #1 (permalink)
Default Unable to Disconnect from Dataone.
hai buddy,
i got dataone broadband yesterday.i connected the modem to pc thru usb & configured. the connection is ok but there is no option to disconnect. i tried "Disable network" but its showing that some protocols aint plug and play so u cant do this.and when i clicked "safely remove your hardware" its also showing same error.What to do guys please help me.
Words that soak into your ears are whispered...not yelled.
krdevilal is offline
Old 08-09-2005, 12:39 AM   #2 (permalink)
sunnydiv
Posts: n/a
wow man, this should be a nightmare for ye,
at least its not time based, and only data based
i hope someone gives u a tips soon
Old 08-09-2005, 05:17 PM   #3 (permalink)
expertno.1's Avatar
you can do this
switch off your modem...u will be disconnected
automatically
expertno.1 is offline
Old 08-09-2005, 06:00 PM   #4 (permalink)
Just Do It
Charley's Avatar
Default Re: Unable to Disconnect from Dataone.
Originally Posted by krdevilal
hai buddy,
There isnt an option to disconnect.
Why wud u want to do so, if u cud simply switch off the modem when not in use and switchback on when u wanna use.
Charley is offline
Old 08-09-2005, 07:22 PM   #5 (permalink)
tell me how do u connect,...isnt there a pppoe dialer u use.If not go to the modem interface apge and disconenct
cyrux is offline
Old 08-09-2005, 07:39 PM   #6 (permalink)
The Incredible's Avatar
how to switch on n off?
The Incredible is offline
Old 08-09-2005, 09:06 PM   #7 (permalink)
Just Do It
Charley's Avatar
*Smiles*.......
Hmm, there is a small knob behind the modem along with the cables/wires attached to the modem. Just push it down to switch off and up to switch on
Hope it helps......
Charley is offline
Old 08-09-2005, 09:38 PM   #8 (permalink)
expertno.1's Avatar
hey hey
even the dialup modem has the same technique
just turn off the knob at the back of the modem
OR OR
just pull out the power plug...
Old 08-09-2005, 09:39 PM   #9 (permalink)
plug out the usb from the comp... u get disconnected or take out the adaptor...
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 09-09-2005, 12:04 AM   #10 (permalink)
yeah...but if i switch off the modem or plug out the USB the system gets hanged and to add more troubles now my land phone isnt working What to do now ???
Old 09-09-2005, 06:16 AM   #11 (permalink)
expertno.1's Avatar
then the problem with your drivers coz if after automatic discconet your OS doesnt diesonnect or closes the port then the problem is with the drivers also
get your drivers reinsatlled
Old 09-09-2005, 11:24 AM   #12 (permalink)
Just Do It
Charley's Avatar
M8, didnt u ask the tel exchange ppl to install it for u?
Bfore its too late , call up the 1600 424 1600 number and ask for help.
Charley is offline
Old 09-09-2005, 11:32 AM   #13 (permalink)
I use the Ethernet Option .. if USB gives problems leave it and use the Ethernet Option .. only with the Ethernet Option u use the pppoe dialer .. u need the dialer if u use the modem they provide .. i got a Dlink modem and it aint need any dialers .. i switch on my pc and viola, i am connected to the internet
Experts Say, Something Went Wrong With the Jet Crash ;)
D1G1TiZed is offline
Old 09-09-2005, 11:51 AM   #14 (permalink)
Just Do It
Charley's Avatar
Third party softwares r not recommended. The modem has an inbuilt program to set up the Internet settings i.e if u take it from BSNL.
Charley is offline
Old 09-09-2005, 04:02 PM   #15 (permalink)
Originally Posted by expertno.1
hey hey
OR OR
BTW did u mnt that every dial-up modem have a knob or only those provided by bsnl have knobs.
if its true then do u know whether D-link 56kbps modems have da knob or not.
Old 09-09-2005, 07:30 PM   #16 (permalink)
godsownman's Avatar
Default Ethernet
Why dont you connect it through the Ethernet card then you shall not face any such problems and you can safely pull out the adaptor when you finish your work.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 09-09-2005, 11:30 PM   #17 (permalink)
But i think the USB is much faster compared to Ethernet nah? and now i am able to execute "safely remove your hardware" option to remove the modem.Any another option ?
Old 09-09-2005, 11:41 PM   #18 (permalink)
godsownman's Avatar
I was told by the fellow who setup my connection that the Ethernet method is faster and USB takes up more time and makes connection slower.
I searched on How stuff works and found out that though there are advantage of connecting it to a USB port, if there are other devices connected it can slow down your connection speed .
They recommend connecting it to a Ethernet card .
I quote them below
Originally Posted by How Stuff Works
If you have read How USB Ports Work, then you know that a USB port has a maximum data rate of 12 megabits per second (Mbps). However, of that available bandwidth, an individual USB device can use only up to 6 Mbps. And if you have several devices attached to the USB ports and they pump lots of data, this competition may further lower the data rate.
An Ethernet card, on the other hand, connects directly to the computer's bus. Ethernet cards come in two flavors: one that accepts 10 Mbps, and another that accepts 100 Mbps.
If you are on a cable modem late at night with no one else sharing the line (see How Cable Modems Work for a discussion on sharing), the cable modem can run at data rates faster than 10 Mbps. In normal circumstances, however, a few megabits per second is far more likely. Taking this into account, you could install a 100-Mbps Ethernet card if you want the best possible peak performance. Also, an Ethernet card is likely to be more consistent, since it is dedicated to network traffic (as opposed to a USB connection, which may handle traffic from a number of devices). One difference is the ease of installation. To install an Ethernet card, you have to open the computer casing, while the USB option takes 5 seconds to plug it in.
Source :http://computer.howstuffworks.com/question667.htm
Old 10-09-2005, 09:37 AM   #19 (permalink)
connecting and configuring in ethernet is easier i feel
Old 15-09-2005, 05:57 PM   #20 (permalink)
wats ethernet?
Old 15-09-2005, 06:16 PM   #21 (permalink)
expertno.1's Avatar
Hi The Incredible ,
well i have the d-link 56 kbps modem and it has the knob at the back
wats ethernet?
Ethernet is the most widely-installed local area network technology. Specified in a standard, IEEE 802.3, Ethernet was originally developed by Xerox and then developed further by Xerox, DEC, and Intel. An Ethernet LAN typically uses coaxial cable or special grades of twisted pair wires. The most commonly installed Ethernet systems are called 10BASE-T and provide transmission speeds up to 10 Mbps. Devices are connected to the cable and compete for access using a Carrier Sense Multiple Access with Collision Detection (CSMA/CD) protocol.
www.virtualaccess.com/Products/glossary.htm
Ethernet is the most widely installed local area network technology. The most commonly installed Ethernet systems are called 10BASE-T, providing transmission speeds up to 10 Mbps. Fast Ethernet LANs, 100BASE-T, provide transmission speeds up to 100 Mbps.
www.stallion.com/html/support/glossary.html
Old 15-09-2005, 06:23 PM   #22 (permalink)
expertu bhaiya
kya mera modem bhi ethernet wala hai?
kya ehthernet bhi pci slot mein lag jayega?
Old 15-09-2005, 06:55 PM   #23 (permalink)
godsownman's Avatar
Ethernet is a card the Netwok interface card or the LAN card which is connected in the motherboard.
These cards are used to connect 2 computers to form a network or they are also used to connect to the Broadband internet.
- by bhaskar
- by Soumik
