Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 02-01-2012, 11:06 PM   #1 (permalink)
webgenius's Avatar
Default Dataone plan and router selection help
Hi folks,
I plan on getting Dataone Unlimited usage Home plan. Which plan should I choose? I'm interested in 750 bucks per month gor 512 kbps. But it has 2 plans: Which plan is better of the two?
I plan on getting a router online from ebay or Flipkart. I plan on setting up a home network with this router. WiFi would be used by handsets and laptop. I want to connect the printer and external hard-drives also to the router, so that I could trigger prints over the network and download stuff to the external hard-disk. These contents will be used to stream onto a laptop, mobiles, and SmartTV.
Which router is a good choice for the above mentioned needs?
I found one router that might do the above mentioned tasks: link
Will this work? Any alternatives?
24 hours, 56 views and no reply...Come on folks, I need your opinion on this...
webgenius is offline   Reply With Quote
- by bhaskar
- by Soumik
