Re: Connect BSNL phone and modem in different rooms
yes..extend the wire to the room where u need your internet/phone connection is required from the place where the ADSL splitter is there and you are good to go...
Better use a single wire if you are extending the Modem wire since Cable interconnects will cause signal drops.
Dell Studio 1555 - Intel Core 2 Duo P8600 @ 2.40 GHz, 3 GB RAM, 500 GB HDD, ATI Mobility Radeon HD 4500 | PC - Intel Pentium 4 1.7 Ghz:wink:, 1 GB RAM, 160 GB HDD, Mercury 845 GL NDSMX | Samsung Galaxy S Plus - 1.4 Ghz, 512 MB RAM, 16 GB Internal, 8 GB SD
