Re: TV Tuner and DTH
you can record TATA sky HD programmes into u r TV tuner card. the protection is from antenna to the STB, as these signals will be encoded.
so u will be able to record from STB to PC, but the controlls will be in STB (ex changing channels).
concept is simple: anything which u can see u can record!
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
