Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 02-11-2011, 04:09 PM   #1 (permalink)
rahul2002's Avatar
Default wireless internet connection
Hi, i will be purchasing a laptop later this month. Now, i use a local braoadband connection from meghbala broadband (wired) for my pc. I want to replace it with a wireless internet service which i can use both on my pc and laptop.I live in kolkata. Can anyone suggest
1. A good wireless ISP
2. good packages ????
Phenom II X4 965/msi 790fx-gd70/XMS3 4gb ddr3 1600mhz ram/corsair carbide 400r:))/XFX hd 5770/corsair TX 750/ AOC F22s/ WD caviar green 500gb HDD/ APC 600/steelseries merc kb/ROCCAT KONE:):)
rahul2002 is offline   Reply With Quote
Old 02-11-2011, 04:45 PM   #2 (permalink)
mithun_mrg's Avatar
Default Re: wireless internet connection
^^what type of connection is that
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 02-11-2011, 06:44 PM   #3 (permalink)
socrates's Avatar
Does your connection come to your house thru a LAN cable or thru a cable modem? You could in all probably be able to use a wifi router but
only if your current ISP should allow this (If you ISP does not allow multiple logins you have an option of MAC cloning )
also you should know if your ISP use DHCP or fixed IP
also whether it's a always on connection or you have to connect thru a s/w on your computer.
be what you are
and say what you feel
bcoz those who mind, don't matter
and those who matter, don't mind !!
socrates is offline   Reply With Quote
Old 02-11-2011, 08:48 PM   #4 (permalink)
rahul2002's Avatar
^^^ i want to totally surrender my current connection and opt for something like TATA photon or BSNL EVDO. so, i want to know can i use them both on my pc and laptop???
Old 03-11-2011, 07:23 AM   #5 (permalink)
mithun_mrg's Avatar
if u want to share the internet avoid those and get bsnl BB i think is the best option correct me if i am wrong because i don't have much idea about the available options in ur place
Old 03-11-2011, 11:21 PM   #6 (permalink)
rahul2002's Avatar
I want something like TATA photon or BSNL EVDO. Has anyone have any idea about the packages available in kolkata???
Old 04-11-2011, 09:36 AM   #7 (permalink)
socrates's Avatar
Which ever USB dongle you choose for broadband connection just make sure that it gives you the promised speed at the locations you are going to use it in eg home or some other location. A friend recently went in for Reliance in spite of telling him what I mentioned above he did not try it out as I mentioned & now is saddled with a white elephant as it does not give that speed as promised at his residence. Apparently all cell sites have not been upgraded to give this speed or they have massive down time.
be what you are
- by bhaskar
- by Soumik
