Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 22-10-2011, 05:33 PM   #1 (permalink)
AJK
Default [SOLVED] Need help regarding wifi on my netbook
Hey ppl just got an mtnl wifi router at my house 3 days back .. it works fine with my PC ,netbook and even my ipod but the problem is when im downloading something on my netbook(usually on torrents) and i shut the lid off it stops downloading although when i open the the lid again it resumes downloading i donno if im doing something wrong here ... need ur help guys as to how i can continue downloading even when the lid is on...
Phenom ii X4 955BE || GIGABYTE GA-880GM-USB3 || SAPPHIRE HD6870 || CORSAIR XMS3 1600 1X4GB || SILVERSTONE ST50F 500W || NZXT GAMMA || BENQ G2220HD ||SEAGATE 1TB 7200.12 || ASUS 24X || APC 600VA
AJK is offline   Reply With Quote
Old 22-10-2011, 05:53 PM   #2 (permalink)
Default Re: Need help regarding wifi on my netbook
It probably goes into sleep/standby mode
Disable it-
Method 3: Close the Lid (Laptop)
To place your computer in the Standby mode by closing the lid to the computer, follow these steps:
Click Start, point to Settings, and then click Control Panel.
Double-click Power Options.
In the Power Options Properties dialog box, click the Advanced tab.
In the When I close the lid of my portable computer box, click Do Nothing.
Click OK or click Apply, and then close the lid of your laptop computer.
How To Enable or Disable the Standby Mode
Old 22-10-2011, 07:32 PM   #3 (permalink)
AJK
Disable it-
hey dude thanks a ton it worked .. i owe u big time thanks again bro
Old 22-10-2011, 08:22 PM   #4 (permalink)
No Problem! Happy to Help
- by bhaskar
- by Soumik
