Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 12-10-2011, 11:27 AM   #1 (permalink)
Default tata sky hd problem
Hi guys,
Recently i upgraded my setup box to hd. I have sont bravia 32'' full hd tv.
My problem is that i the channels like national geo, discovery, few music channels and couple of more channels are getting 1 inch cut from 2 sides.
It used to not happen before. All hd channels and sports channels work fine.
And even sometimes few programs are viewed in cinema scope.Can any one tell what is the problem. Thanks.
imrocking_since92 is offline   Reply With Quote
Old 12-10-2011, 02:03 PM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: tata sky hd problem
make sure the resolution in HD box and TV is set to 1080i.
for me every channel fits the screen. I am using samsung 32''
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline   Reply With Quote
Old 12-10-2011, 04:57 PM   #3 (permalink)
what abt non hd channels like discovery and nat geo do u get them full screen or cinama scope??
Old 12-10-2011, 08:50 PM   #4 (permalink)
khmadhu's Avatar
my package contains discovery and Natgeo both HD. these two channels are also available as non HD channels.
if u r talking about black horizontal bars then its common, if there is a vertical cut, then there may be some problem in settings
- by bhaskar
- by Soumik
