Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 05-10-2011, 09:18 PM   #1 (permalink)
gurujee's Avatar
Smile Tata Photon + queries
Hi all,
after feeling like cheated by bsnl 3g speed and performance, i want to buy a photon+ having heard about its good speed, service etc.
However, Want to know one more thing. Does it assign dedicated IP to every user ? How is rapidshare etc & Torrent downloads ? What technology it uses - 3g(gsm) or rev(cdma) ?
since it has no unlimited schemes, and bsnl evdo has, should i also consider BSNL EVDO ?
gurujee is offline   Reply With Quote
Old 05-10-2011, 09:53 PM   #2 (permalink)
Default Re: Tata Photon + queries
I normally get 60 kbps average downloading. speed on my photon+, and rarely it crosses 100 kbps.. plus it doesn't disconnect frequently like other wireless dongles.
Are you not getting speeds on BSNL 3G? I was thinking of shifting to MTNL 3G here, in delhi. Don't know what the speeds are, and the services, too.
Vedanta is offline   Reply With Quote
Old 06-10-2011, 11:27 PM   #3 (permalink)
Photon+ uses cdma. there are dynamic ips given and as far as speed is concerned, it depends upon your area and also time. better ask for a demo.
speed varies a lot and as far as support is concerned, it is not very good. i have talked to cs people for 7-8 times and i have found MORONS only.
they even blocked some 35 sites including rapidshare (but no torrent block) for 7-8 days last month just like that without any prior info and any proper explanation.
vidhubhushan is offline   Reply With Quote
Old 08-10-2011, 12:22 AM   #4 (permalink)
gurujee's Avatar
Oh..Dynamic IPs that means the same message "you are currently downloading a file, please wait"... !!!
Seems doubtful...ANyway thanks very much for your reply.
Old 08-10-2011, 08:11 PM   #5 (permalink)
Living to Play
gameranand's Avatar
go for MTNL 3G much better than any ISP out there.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 08-10-2011, 08:21 PM   #6 (permalink)
Thanks .. and I am going for Micromax MMX 310G 3G USB Modem, seems the best option.. can u please suggest?
Old 08-10-2011, 09:06 PM   #7 (permalink)
Living to Play
gameranand's Avatar
Well its your call but MTNL have best plans. Rs 4500 for 6 months unlimited.
Old 11-10-2011, 07:37 PM   #8 (permalink)
Yes I will use MTNL with the Micromax modem. Currently I have considered MMX 310G which is max 3.6 mbps and can be used with any sim.. do u think speeds will be more than this limit? I think 7.2 mbps will currently be a waste of money, isn't it?
Old 13-10-2011, 05:23 AM   #9 (permalink)
Living to Play
gameranand's Avatar
Yes opt for 3.6 for now but if you want to be future prood then you can go for 7.2
Old 13-10-2011, 04:52 PM   #10 (permalink)
gurujee's Avatar
got photon+. seems satisfied with the speed.
orissa has bsnl. and its slow. photon is expensive but its worth if u are not dl hungry.
Rs.1200 for 10gb unlimited
Old 13-10-2011, 06:50 PM   #11 (permalink)
Congrats!
But how is 10 gigs unlimited
I guess you are lucky as you are getting good speeds!
Old 13-10-2011, 07:41 PM   #12 (permalink)
JojoTheDragon's Avatar
^ Beware, that 10gb is Upload + Download.
| Steam: jojothedragon | Origin : jojothedragon | PSN : jojothedragon |
TDF @ Steam
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
JojoTheDragon is offline   Reply With Quote
Old 13-10-2011, 09:49 PM   #13 (permalink)
Living to Play
gameranand's Avatar
Originally Posted by thetechfreak View Post
Congrats!
He must be talking about FUP.
Old 15-10-2011, 11:31 PM   #14 (permalink)
gurujee's Avatar
10 gb in 3.1mbps, afterwards speed will be 155kbps
Old 16-10-2011, 09:34 AM   #15 (permalink)
Living to Play
gameranand's Avatar
thats terrible.
Old 16-10-2011, 11:16 AM   #16 (permalink)
Super Moderator
asingh's Avatar
I doubt they FUP. I have the 15GB plan, once I cross it they start to charge me extra but the speeds remain the same.
asingh is offline   Reply With Quote
Old 18-10-2011, 12:05 AM   #17 (permalink)
gurujee's Avatar
yes, its shocking...i wasnt aware of this. Just sent a 700mb file to my bro. and checked the upload is calculated as cumulative usage...
Old 18-10-2011, 05:55 AM   #18 (permalink)
Living to Play
gameranand's Avatar
Acually he said about UL so I thought its FUP. Thanks for clarification.
Old 24-10-2011, 06:44 PM   #19 (permalink)
this 10GB comes under FUP (10GB Unlimited plan). this 10GB is upload + download and after this the speed goes down to 150 something
- by bhaskar
- by Soumik
