Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 03-10-2011, 04:23 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Huaewi e173 3g modem problem
got a unlocked huawei E173 3G modem
but when i plug it first it shows as huawei modem detected
and shows a problem occurred during hardware installation .your hardware will not work properly
and the modem appears as usb device
not getting detected
diagus is offline   Reply With Quote
Old 03-10-2011, 05:29 PM   #2 (permalink)
Default Re: Huaewi e173 3g modem problem
Could you post a screenshot and write a little more details about your problem.
Old 03-10-2011, 05:45 PM   #3 (permalink)
the modem is only recognized as a storage device
the software shows modem not connected
is the modem faulty just purchased today
http://i52.tinypic.com/2jg5nye.jpg
http://i52.tinypic.com/29qmhhi.jpg
Old 03-10-2011, 05:57 PM   #4 (permalink)
Here are a few things you should try before RMA'ing it :
1. try to use the modem on another computer and see if it is possible for you to configure it
2. Try to factory resetting it by putting a safety pin through the hole in back.
3. Reinstall all software and driver associated with it.
if it will not work even after doing these it will be a safe bet that the device may be defective.
Old 04-10-2011, 09:14 AM   #5 (permalink)
now the modem is detected
but the problem is when i try to connect the modem get disconnected
the modem gets disconnected frequently
http://i51.tinypic.com/29lnr6o.jpg
Old 04-10-2011, 10:22 AM   #6 (permalink)
eagle_y2j's Avatar
try another port
Registered LINUX USER #438929
eagle_y2j is offline   Reply With Quote
Old 04-10-2011, 11:38 AM   #7 (permalink)
thanks
yes it was usb port issue now problem solved
buy the way how to install mobile partner software in it
so that it open automatically when i plug in.
the modem has a default megaphone modem software
that pop up everytime i plug in.
Old 04-10-2011, 02:36 PM   #8 (permalink)
funskar's Avatar
Smile Re: Huaewi e173 3g modem problem
Originally Posted by diagus View Post
thanks
Download this huawei Dashboard update _ http://www.dc-files.com/UTPS21.003.2...4.793.B717.zip
Then unrar it nd disconnect ur modem & exit icon from system tray & run the Huawei Dashboard Update file. Now when the Huawei Dashboard Update will Finsih u will b Having Mobile Partner setup Installed in ur Modem
funskar is offline   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/broadband-dth/147153-huaewi-e173-3g-modem-problem.html
HUAEWI - Virgilio Ricerca Web This thread Refback 25-11-2011 09:59 PM
- by bhaskar
- by Soumik
