Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 23-08-2011, 08:53 PM   #1 (permalink)
baiju's Avatar
Default Limit Broadband Usage
I have a BSNL night unlimited 2mbps plan. The free data usage is 1.5GB. I have been using it carefully so as not to cross the limit. However, this month the usage exceeded by around 700MB. Is there any software (freeware better) which can monitor data usage and alert/block the connection after a set limit (1.5GB)? The software should allow network traffic between 2am and 8am irrespective of this limit.
baiju is offline   Reply With Quote
Old 23-08-2011, 10:09 PM   #2 (permalink)
not a newbie.....
papul1993's Avatar
Default Re: Limit Broadband Usage
When I used to have this plan i crossed the limit by 2 gb sometimes.
papul1993 is offline   Reply With Quote
Old 23-08-2011, 11:27 PM   #3 (permalink)
127.0.0.1
mitraark's Avatar
Well there is no Limiting SOftware but I use Boradband Usage Meter to check usage everyday.
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
mitraark is offline   Reply With Quote
Old 25-08-2011, 07:20 PM   #4 (permalink)
baiju's Avatar
thanks for the replies. I actually check data usage through sms and shaplus tool. However some one used the connection without knowing the limit while I was away for a few days.
- by bhaskar
- by Soumik
