Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 11-08-2011, 08:01 PM   #1 (permalink)
The Assassin
Cybertonic's Avatar
Default Multiple problems with Airtel
Hi,
I'm using airtel Turbo 30GB plan with 4mbps speed. I switched to that plan from impatience 899(4mbps 6GB) this month and have been getting problems ever since.
1. Airtel seems to be throttling the download speed. While download torrents i can barely touch 30kbps with the exception of a few second long boosts of upto 200kbps. Till last month i was getting the full 500kbps on the same downloads. The story is similar for non-torrent downloads too. I'm getting 250kbps while watching videos online and speedtest.net works weirdly showing 8mbps sometimes.
2. I'm getting the DNS lookup failed error although the net starts working properly by itself in 10-15 minutes. I can still play counter-strike online though but can't surf the net(it confirms that it is a DNS error).
I'm using a beetel wifi router provided by airtel as well as a wireless n router from netgear. Both of them are giving the same problem.
Please help.
Nothing is true. Everything is permitted.
Steam : $/@$]-[ DK
http://steamcommunity.com/profiles/76561198047340352
Cybertonic is offline   Reply With Quote
Old 11-08-2011, 10:07 PM   #2 (permalink)
iDota
Sarath's Avatar
Default Re: Multiple problems with Airtel
Originally Posted by Cybertonic View Post
Hi,
Please help.
I am getting the same DNS lookup problem with airtel and switched to google.
Alls fine now.
Online Shopping guide - PART IIIPS3™ master guide
Gaming:♦ PS3 ♣ i5|HD6970 Gaming RIG | Dell U2311H review iΡod & iPhone 4 ♥ Xperia™ Arc review
Audio gear: Logitech Z623 | Klipsch X10 | Siberia V1 | M1 | M2 | CX180 | | | Article/Discussion: PS3™ vs PC
Sarath is offline   Reply With Quote
Old 11-08-2011, 10:30 PM   #3 (permalink)
The Assassin
Cybertonic's Avatar
Are you having any throttling issues?
Steam : $/@$]-[ DK
Old 11-08-2011, 11:46 PM   #4 (permalink)
Techie By Heart
mavihs's Avatar
i'm also having probs in watching videos online!!!!
will try changing my DNS!!!
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 12-08-2011, 12:59 AM   #5 (permalink)
Super Moderator
asingh's Avatar
Airtel traffic shapes.
asingh is offline   Reply With Quote
Old 12-08-2011, 09:56 AM   #6 (permalink)
Manchester United <3
Ishu Gupta's Avatar
1) Use 'force encryption' from utorrent prrferences.
2) Use Google DNS.
I'm using the Turbo 30GB plan and all is working well.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
- by bhaskar
- by Soumik
