Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 05-08-2011, 04:37 AM   #1 (permalink)
Pragadheesh's Avatar
Question Wireless security get deleted every time
Hi,
I am using BSNL broadband connection with Huwai WA1003A modem cum router. I go to the router IP and set up wireless security like
1) MAC filter - Enabling Access list
2) WPA Security
But the next time I connect my computer, I find all the wireless security stuffs to be removed. The network becomes unsecured once again.
What is the reason for this and how do I fix it.?
Pragadheesh is offline   Reply With Quote
Old 05-08-2011, 07:20 AM   #2 (permalink)
Default Re: Wireless security get deleted every time
Originally Posted by Pragadheesh View Post
Hi,
2) WPA Security
I have same router ,to save the setting u have to select option save all setting ,its under last 2nd tab[not at home atm to tell u exact tab name]
AMD Phenom II X6 1055T ,Benq G2220HD 22 ,GIGABYTE GA-880GM-UD2H ,COOLER MASTER Elite 310 ,CORSAIR 2GB 240-Pin DDR3 X3[6GB] , FSP Saga II 500 W HD 5750 . Hyper 212+ OS :Win 7 64 bit
Rajesh345 is offline   Reply With Quote
Old 05-08-2011, 11:58 AM   #3 (permalink)
Thanks. I didnot notice that.
Old 05-08-2011, 07:18 PM   #4 (permalink)
Tools > System commands > Save all > then reboot the router (Restart option or manuel)
- by bhaskar
- by Soumik
