Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 02-08-2011, 08:24 PM   #1 (permalink)
Question prob with broadband modem
I have a BSNL broadband connection.
The ADSL link of the modem always getting disconnected when i am using internet.
After a while ADSL gets established, and again disconnects. it doesnt stay even for a minute.
what i found out is that this problem i am facing at night time frequently.
During day time, this problem some time occurs but not frequently.
I contacted the service man, he came and changed the entire wiring. even then im having this problem.
what might be the problem for this and any solution for this?
rajiv.ganti is offline   Reply With Quote
Old 02-08-2011, 09:03 PM   #2 (permalink)
Default Re: prob with broadband modem
The problem may lie outside. There may be bad joints where your phone line is joined to the BSNL main line or at their junction box. The joint may be mechanically firm, but the electrical contact is often poor due to corrosion, especially in the rainy season. Phone linemen often just twist the wires together and leave them exposed to the weather. There could also be leakage to earth through accumulated dirt and moisture. See if there's anything you can check yourself near your residence.
You can also check the line condition by connecting a telephone to the line and listening for any line noise. This noise is not the hissing sound you hear on the phone when you use a phone that shares the same line with a modem using a splitter. That noise is normal. The abnormal sound is an irregular crackling sound and is best tested by connecting the phone directly to the incoming line without passing through a splitter.
pimpom is offline   Reply With Quote
Old 02-08-2011, 09:20 PM   #3 (permalink)
Mozilla Rep
sygeek's Avatar
It's BSNL's internal problem, not yours. Welcome to the world of BSNL.
sygeek is offline   Reply With Quote
Old 02-08-2011, 10:45 PM   #4 (permalink)
i hav one doubt.
does the disconnecting of the ADSL link depend on number of users using the internet in my area at same time?
i mean if there are more users, then will the ADSL get disconnected frequently?
Old 02-08-2011, 11:14 PM   #5 (permalink)
Mozilla Rep
sygeek's Avatar
Originally Posted by rajiv.ganti View Post
i hav one doubt.
nothing like that
- by bhaskar
- by Soumik
