Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 28-06-2011, 03:27 PM   #1 (permalink)
Blu For Life Hail Chelsea
clinton's Avatar
Default How to check my Internet Usage?
Hello Friends,
I use a Dlink wi-fi modem to access internet on my PC and and cell phone.
As it is a ever connected net(not Dial up) i cant see the the current Received and Sent usage as it is show in Dial up connection.
The only thing i can do is to c the status of the network,but its shows usage in terms of Packets.How can get the usage (both incurred on PC and on Wireless device) in either kb or mb?
Please Help.
Thank You...
clinton is offline   Reply With Quote
Old 28-06-2011, 03:30 PM   #2 (permalink)
Manchester United <3
Ishu Gupta's Avatar
Default Re: How to check my Internet Usage?
Use a bandwidth monitor app like shaplus.
This will only track the usage from your PC though.
If you are using BSNL BB, you can check usage on their portal.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 28-06-2011, 03:35 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
@clinton: u can use DUMeter (I m using this) to monitor the data usage...
or Net Worx (correct me if im wrong) or Netmeter
Old 28-06-2011, 04:14 PM   #4 (permalink)
clmlbx's Avatar
NetWorx is best for this Job
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is offline   Reply With Quote
Old 28-06-2011, 05:30 PM   #5 (permalink)
clinton's Avatar
thanks Guys,Net Worx just works fine but it only tracks the usage done on the PC,not using the wif-fi network....
Old 28-06-2011, 06:19 PM   #6 (permalink)
@clinton: Thanks for raising this question. I was also searching for the same.
GPS: The best way to navigate safely and securely.:smile:
rajeevk is offline   Reply With Quote
Old 29-06-2011, 04:10 PM   #7 (permalink)
abhidev's Avatar
is net worx a win 7 gadget or a separate app??
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is offline   Reply With Quote
Old 29-06-2011, 04:27 PM   #8 (permalink)
Fullbring
Zangetsu's Avatar
its a separate app
- by bhaskar
- by Soumik
