22-06-2011, 11:32 PM
BSNL Broadband speed
hi,
I have recently changed my plan in hope to get faster speed to BSNL BB Home Combo ULD 900
But still my download speed is up to 1.7mbps only.
I need faster speed--at least 3-4mbps--What to do?
Why BSNL is not giving the speed it promises?
22-06-2011, 11:39 PM
Re: BSNL Broadband speed
Firstly, the plan says that the bandwidth is 4 mbps upto 8 GB then it will drop to 512 kbps. Now download speed is 1/8 of the bandwidth, which in your case is 512kbps, upto 8 GB and will drop to 64kbps after downloading 8 GB of data.
22-06-2011, 11:45 PM
MW3>BF3
In this plan u will get 256kbps not 512kbps after 8gb
23-06-2011, 06:53 AM
Thats the right speed you are receiving in 4 MBPS connection. After you cross 8 GB limit, it will be reduced
23-06-2011, 07:43 AM
Unique Personified.......
no need to worry ........aftr 8gb speed will b reduced....
23-06-2011, 09:14 AM
hi,
I am paying more to get more speed. My previous plan speed was up to 2mbps (actually I was getting up to 1.2-1.6mbps) and @ Rs 500 per month.
But in new plan where I am paying almost double, speed is the same.
I opted new plan for better speed and not for amount of data downloaded.
Kindly help
23-06-2011, 10:20 AM
Fullbring
@joshiks7: how much speed did BSNL mentioned in BSNL BB Home Combo ULD 900???
23-06-2011, 12:51 PM
^^ 4Mbps upto 8 GB, 256 Kbps beyond 8 GB.
23-06-2011, 03:29 PM
Hi,
4mbps up to 8gb and 256 kbps thereafter
23-06-2011, 04:16 PM
Fullbring
Originally Posted by joshiks7
Hi,
so for a 4mbps download speed is 500kbps approx
23-06-2011, 05:17 PM
Anyone have any idea about cheap and best broadband plan in Bihar........Please share. I want it for home use with my laptop. If any night plan then good.
GPS: The best way to navigate safely and securely.:smile:
23-06-2011, 10:07 PM
hi,
What I am talking about is download speed as checked on speedometer and not actual data download.
Why this download speed is same (approx. 1.5mbps) in both plans (of 2 and 4mbps resp.)
01-07-2011, 10:19 AM
127.0.0.1
hi,
Go to Speedtest.net - The Global Broadband Speed Test and see what speed you are getting.
Also , in uTorrent , see what max speed you are getting, It should be around 450-500 KB/s.
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
01-07-2011, 02:27 PM
iDota
4Mbps= 0.5 MBps = 4000Kbps = 500KBps
Please avoid confusion by posting right values.
Speed test measures in mbps and advertised speeds are also in mbps so there should be no difference.
I have airtel 4mbps and speedtest shows 4.1mbps so I get promised speeds. If you are not then you have a reason to complain.
01-07-2011, 10:00 PM
I spoke to BSNL SDE 2 days ago.
Now---
But other site---
Which is correct??
01-07-2011, 10:47 PM
127.0.0.1
Well Speedtest does give fairly accurate results for BSNL.. but this one is weird  Did you try downloading anything ? Antivirus Updates usually maxxes out download speed , see at what speed it is downloading. Highly seeded torrents too..
My Speedtest :D
02-07-2011, 04:09 AM
Mozilla Rep
Instead of these online services, use a download manager and see the speed you get. Also, you should be aware of the difference between kilobytes (KBps) and kilobits (Kbps).
LinkBack to this Thread: http://www.thinkdigit.com/forum/broadband-dth/142794-bsnl-broadband-speed.html
| Posted By |
For |
Type |
Date |
| BSNL Broadband speed |
This thread |
Refback |
28-09-2011 04:49 PM |
