Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 15-06-2011, 04:55 PM   #1 (permalink)
Unhappy Less Speed
Hi I'm using to "DSL_Unlimited_599" plan: Price-Rs599/- , Speed -512kbps and I'm getting a download speed of 60kbps. My friend is using DSL_Unlimited_395: which is Priced Rs395/-, Speed-320kbps and he his getting download speed of 120kbps .Is anyone facing the same problem? Or is it just me? Please let me know?
Techfreak2 is offline   Reply With Quote
Old 15-06-2011, 05:02 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: Less Speed
If your bandwidth is 512kbps then download speed of 60kBps is fine.
Generally it's Bandwidth / 8. As they advertise it with kbps = kilo bit per sec. and dividing it by 8 makes it to kBps = kilo bytes per sec.
So for 512kbps connection 60kBps download speed is really ok.
Don't know about your friend, may be he's getting the hike because of some fault in network, or may be he's lying to you about the plan
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline   Reply With Quote
Old 15-06-2011, 05:51 PM   #3 (permalink)
There is no question of my friend fooling me coz I saw his bill by myself. This is Definitely due to Network Problem.
Old 15-06-2011, 05:55 PM   #4 (permalink)
Simply a DIGITian
In that case consider himself lucky, and for your case your speed is perfectly fine for 512kbps connection.
Old 15-06-2011, 06:00 PM   #5 (permalink)
Democracy is a myth
rhitwick's Avatar
As Krishnandu told, 60KBps is optimum speed
And @Amrut, dude were all that bold font and color change really necessary?
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline   Reply With Quote
Old 15-06-2011, 07:42 PM   #6 (permalink)
Don't get greedy at KBPS. There is conversion of speed like this::::
The speed they promise in KBPS gets divided by 8. For example- In case of 750U THey promise 512 kbps but it gets divide by 8 and the actual speed you get is 60 kb/s means you can download 60 kilobytes per second.
Thank you
roshanlaladchitre is offline   Reply With Quote
Old 15-06-2011, 09:53 PM   #7 (permalink)
Wise Old Mouse
mrintech's Avatar
I am using AirTel 512 Kbps Plan and Max I get is 68-69 Kbps
320/8 = 120 is impossible, unless your friend is relative of some officer at ISP
- MrinTech :)
mrintech is offline   Reply With Quote
Old 16-06-2011, 01:41 AM   #8 (permalink)
127.0.0.1
mitraark's Avatar
8 Bits = 1 Byte.
Internet Speed measured in => Kbps = Kilo BITS Per Second
=> 8 kilo bits per second = 1 Kilo Byte per second.
Hence , 512 kbps = 512/8 = 64 KB/s
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
mitraark is offline   Reply With Quote
- by bhaskar
- by Soumik
