Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 09-06-2011, 02:04 PM   #1 (permalink)
ajayritik's Avatar
Default Can I setup BSNL BB connection using my Airtel Wifi Router?
Hi guys,
I have had both Airtel and BSNL BB connection. With the BSNL connection I have a wired modem and through Airtel I have a wireless Wifi router.
Currently in my area I have only BSNL BB available. Is it possible for me to setup my BSNL connection using the existing Airtel Wifi Router?
ajayritik is offline   Reply With Quote
Old 09-06-2011, 02:05 PM   #2 (permalink)
Manchester United <3
Ishu Gupta's Avatar
Default Re: Can I setup BSNL BB connection using my Airtel Wifi Router?
Yes .
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 09-06-2011, 02:09 PM   #3 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Yes, you can use any ADSL modems.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline   Reply With Quote
Old 09-06-2011, 02:23 PM   #4 (permalink)
ajayritik's Avatar
How do I set this up? Can I get rid of the old BSNL modem altogether or do I need to continue using it?
Old 09-06-2011, 03:36 PM   #5 (permalink)
Simply a DIGITian
Yes, you can throw away your BSNL Modem and get a new modem. Depends on you.
Old 09-06-2011, 04:33 PM   #6 (permalink)
ajayritik's Avatar
Krishnandu I don't want to get a new modem. I was checking if I can use my existing Airtel Wifi Router/Modem with my BSNL connection.
Old 09-06-2011, 04:35 PM   #7 (permalink)
Simply a DIGITian
Yes, you can use any ADSL modem. That's what I said on first post. But then you asked can you get rid of that BSNL one too??
Old 10-06-2011, 12:05 PM   #8 (permalink)
You will have to change the VPI and VCI to 0 and 35 respectively if you want to use your Airtel modem with BSNL. Airtel works on a different VPI and VCI - 1 and 32.
Old 10-06-2011, 12:22 PM   #9 (permalink)
Wise Old Mouse
mrintech's Avatar
@OP
Changing appropriate settings in the Router will make BSNL Connection work with AirTel
Give Model Numbers, so I will be able to offer more help
- MrinTech :)
mrintech is offline   Reply With Quote
Old 10-06-2011, 02:00 PM   #10 (permalink)
ajayritik's Avatar
Thanks to all you guys! Without making any changes to the settings whatsoever I was able to setup my Airtel Wifi router with BSNL connection.
However I have one tricky situation I hope somebody here can help me on this.
In the room where I have the BSNL Phone line available I don't have sufficient space to keep my desktop. However I can connect in this room using the laptop. I have my desktop in the other room wherein I don't have the BSNL cable available currently. Do I need to have a wired cable going from the desktop all the way to the first room to have a net connection? Is there some way I can connect to the router/modem in other room with my desktop without having to use any wires i.e. wireless?
If this option doesn't work out then can I have the BSNL line hooked upto the router and then connect wireless from the second room using my laptop? Considering that I don't have any ethernet cable connected to the modem?
Old 10-06-2011, 02:43 PM   #11 (permalink)
Get a Wifi PCI card or a USB dongle for your desktop.
Old 10-06-2011, 03:15 PM   #12 (permalink)
ajayritik's Avatar
How much would a Wifi PCI card cost and the USB dongle?
Could you let me know more details on this USB dongle?
Old 10-06-2011, 03:26 PM   #13 (permalink)
Ishu Gupta's Avatar
Linksys WUSB54GC Portable Wireless
Linksys WMP54G Wireless-G PCI Adapter
Wireless G 802.11g USB Network Adapter (F5D7050 )
Old 10-06-2011, 05:48 PM   #14 (permalink)
ajayritik's Avatar
Looking at the cost involved I would rather prefer getting a technician and having the cable extended to the second room.
Old 13-01-2012, 11:50 PM   #15 (permalink)
Post Re: Can I setup BSNL BB connection using my Airtel Wifi Router?
Hi
i am trying to use my old airtel adsl2+router with my bsnl broadband but no success.
The model is beetle 440TXI (adsl2+router) . can anybody help me with its configuration on BSNL broadband.
Csharp is offline   Reply With Quote
- by bhaskar
- by Soumik
