Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 05-05-2011, 11:07 PM   #1 (permalink)
quicky008's Avatar
Unhappy Experiencing constant link failures on BSNL Broadband-immediate assistance required.
I have been experiencing frequent link failures on my Bsnl broadband connection for the last couple of weeks-as a result of this ,i get disconnected every now and then,which is utterly exasperating to say the least.(I've had link failures atleast 3-4 times as I was composing this message).I am currently using their home UL 750 data plan with a Siemens c2110 modem that was purchased directly from BSNL.
I reported the matter to the nearest telephone exchange but to no avail.A bsnl employee suggested that the problem was occurring as my PC was infected with viruses and there was no problem whatsoever with my connection!!After discussing the matter with him at length,i finally succeeded in convincing him that my telephone line must have developed a fault.
So one of their so-called engineers visited me today and performed some routine checks on my connection-he narrowed down the cause of link failure to the presence of noise on my telephone line-this seemed to be the likely cause to me too as for a while,I have been hearing a lot of extraneous sounds while talking on the phone.After hours of troubleshooting,he managed to eliminate the noisiness almost completely and this resulted in a significant reduction of link failures as well(it was still occurring but not as frequently as it was earlier-previously,link failures occurred once every few minutes but after the engineer's intervention,it was occurring once every 40-45 mins or so).He said that there was nothing more he could do about it and left.
However,to my great dismay,the noisiness on my line has resurfaced since evening and this has also increased the frequency of link failures to a great extent.I am totally perplexed and frustrated with this matter.Can anyone suggest why this is happening?Why do link failures generally occur?What should i do now to get this problem fixed?Please help
quicky008 is offline   Reply With Quote
Old 06-05-2011, 01:11 AM   #2 (permalink)
Default Re: Experiencing constant link failures on BSNL Broadband-immediate assistance requir
Hello Friend. I experienced the exact problems you are currently facing in the very first year i got my BSNL DataOne Broadband connection.
Presently, i do not face the problem you have mentioned in your initial post. Perhaps, it is because our local telephone exchange shifted all the lines (phase by phase) to a "new" exchange. This is what our local JE told me over a telephonic conversation.
Coming to your problem, i would suggest that you inspect your telephone line personally or better, request your local lineman to do it for you. Make sure there are no joints at various lengths of the wire. If the need be, request your telephone lineman or a higher authority to change your existing telephone wire with a new one.
Also, check the ADSL statistics on your Router page. Type 192.168.1.1 in the address bar of your web browser. The User Name & Password for the router page is admin.
In your Router page, look out for SNR Margin (dB) & Attenuation (dB).
This could help & serve as a reference -
Have patience & wait for the apt replies of the more experienced techs here. I am confident they will certainly assist & guide you in troubleshooting your problem.
let us all see the "i" in the "u".
insaneYLN is offline   Reply With Quote
Old 06-05-2011, 09:22 PM   #3 (permalink)
quicky008's Avatar
Thank you very much indeed,insaneYln, for lending me your valuable suggestions.I've checked the values of SNR Margin and attenuation of my router and they appear to be well within acceptable limits-therefore,i think the problem doesn't lie with the router but with the telephone line itself(apparently);i have reported this issue yet once more to the concerned authorities and they've promised to send some of their "experts" to diagnose the problem shortly.Lets hope that these elite technicians will be able to shed some light on the matter.Can someone else assist me in identifying the root cause of this problem?Any help concerning this issue will be highly appreciated.
Old 31-05-2011, 09:34 PM   #4 (permalink)
127.0.0.1
mitraark's Avatar
Well usually this happens when it rains or something , but this shouldn;t happen always. Also , the Broadband line should not be split much , it would result n more noise.
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
mitraark is offline   Reply With Quote
Old 31-05-2011, 10:14 PM   #5 (permalink)
What The.... !!!
funkysourav's Avatar
^^ mitraark's right
it happens when it rains and the joints in the wire get wet if improperly sealed
funkysourav is offline   Reply With Quote
Old 01-06-2011, 12:32 PM   #6 (permalink)
@quicky008, you told my story. except that i have not lodged any complain.
Old 01-06-2011, 03:30 PM   #7 (permalink)
New Gen Guru
sujoyp's Avatar
in last 1 year my telephone cable broke from the pole 3 times due to bad weather and rain...initially I complained to bsnl but now i fix it myself...
those sarkari afsar take 7 days to respond... although its illegal to do this but I dont have a choice...
check if ur cable is fine...sometimes out of 2 wires one gets disconnected...the net works but create problems...soo check all joints u have on that cable
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
sujoyp is offline   Reply With Quote
Old 03-07-2011, 05:35 PM   #8 (permalink)
eagle_y2j's Avatar
An application in black and white to SDO broadband of your SSA complaining the issue, it will certainly work .
Moreover you can send copy of this complaint to G.M of your SSA
In my case it worked and whole BSNL broadband staff attended my issue attentively and also arranged a new cable now it works fine!!
Registered LINUX USER #438929
eagle_y2j is offline   Reply With Quote
- by bhaskar
- by Soumik
