Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 04-05-2011, 11:13 AM   #1 (permalink)
masterkd's Avatar
Question Which DTH.
I need to take a DTH connection in my pc with screen resolution 1440*900 (will change to a full HD monitor within this year). After going through the websites videocon seems to be most promising to me, next comes tatasky, reliance and dishtv packages are no good to me.
I'll be mainly watching english entertainment(main), infotainment, news channels. Please suggest me which one i should subscribe to.
Moreover I need a TV Tuner card(within 2-3k) for this too. Please suggest one if you can.
i5 2500K|P8Z68 V PRO|560Ti Hawk|G Skill 8GB 1600MHz|SG 500 GB|WD Passport 1TB|TX850V2|690II Advanced|BenQ G2420HD|Razer Cyclosa Bundle|Razer Goliathus|APC 1.1 KVA|DLink 2730U WiFi Router|Windows 7 X64
Samsung Galaxy Note :hyper:
Steam
masterkd is offline   Reply With Quote
Old 06-05-2011, 12:04 PM   #2 (permalink)
masterkd's Avatar
Default Re: Which DTH.
BUMP....
something..someone..
Steam
Old 06-05-2011, 12:19 PM   #3 (permalink)
Manc
xtremevicky's Avatar
If you can buy the Digit magnazine this month do so as it has a brilliant comparison of all the HD DTH information you will need .
If you want my opinion I will say Airtel HD / Tata Sky HD .
If you like the Post , There is a Rep Button ,
If not then Understand that, There are people with different Opinions !
xtremevicky is offline   Reply With Quote
Old 06-05-2011, 12:29 PM   #4 (permalink)
change is constant!!
khmadhu's Avatar
I am using Tatasky HD + , So far so good..
if u use Tv tuner make sure its HD supported, or u wont get HD effect, (2-3k) budget its difficult..
for HD Tv tuner its costs more.. around (4-5k)
check for AVerMedia AVerTV HD DVR video capture card it looks good
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline   Reply With Quote
Old 06-05-2011, 01:21 PM   #5 (permalink)
iDota
Sarath's Avatar
Method 1:
Tata sky HD+ take it. STB- 4000/-.You will not regret the decision. Just get a monitor with HDMI no need for TV tuner then. All recording will be done by the STB.
The only catch is that you cant transfer the saved files to the PC.
Method 2:
Get Tata Sky HD @2500/-. Get TV tuner card. Connect to HD monitor. This way you can save the files on the PC.
STB: 2500
TV tuner: ?3-4k?
Sarath is offline   Reply With Quote
Old 12-05-2011, 08:42 AM   #6 (permalink)
masterkd's Avatar
thank you for your inputs
everywhere i'm getting people are more inclined to tata sky than videocon..so i'm thinking of tata sky too..i'll contact tata sky soon for subscription!!
Steam
Old 13-05-2011, 01:50 PM   #7 (permalink)
RITESH's Avatar
What is the cost of mpeg 4 dvb s2 tuner card??
reply..............
You tube channel..http://www.youtube.com/user/29riteshkakkar
RITESH is offline   Reply With Quote
Old 20-05-2011, 09:32 AM   #8 (permalink)
RITESH's Avatar
reply..................................
- by bhaskar
- by Soumik
