Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 04-05-2011, 10:38 AM   #1 (permalink)
Simply.. Evolution !!
TheMost's Avatar
Angry Need Help Badly !
Hi
I'm from Chennai ( Tamil Nadu ) .
I've been using airtel Broadband (256kbps - unlimited count during night 9 to mor 8) for the past 5 years ... no problem since then
You know i am a frequent torrenter and b'cause of that i changed my connection to fully unlimited ( morning and noon@512 and night@1mbps ) - I was told so and gave around Rs.1000
To my surprise i found that my speeds raise to around 120KB@sunlight and around 260KB at moonlight
When i en quired with my friends they told me that Airtel has doubled the speed for users using it more than 2 years ...
And i thin k it's true 512 X 2 = 1mbps (ie,around 120KB )
and 1mbps X 2 = 2mbps (ie, around 270KB )
Ya i get these speeds over HTTP links
but with torrents i get only around 60-90 KB ( sunlight)
around 150 KB ( moonlight )
They were open trackers with many backup trackers
I know it depends on seed and leechers
I tried with many torrents and even simultaneous downloads
The torrents had approx 2000Seeds and 1000leechers
U mean they are encrypting my peer connection ??
I am using utorrent and i have forced protocol encryption !
But nothing was the result !
What is this about ??
Any guess ??
TheMost is offline   Reply With Quote
Old 04-05-2011, 11:29 AM   #2 (permalink)
Excessive happiness
furious_gamer's Avatar
Default Re: Need Help Badly !
The speed you are getting over HTTP and torrent will not be same. I am getting around 400Kbps in HTTP download and at same time, using torrent, a mere 250KB. I have seen many forums flooded with same question and here too.
I exactly don't know the reason, let's wait for others to comment.
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is offline   Reply With Quote
Old 04-05-2011, 02:10 PM   #3 (permalink)
TheMost's Avatar
Exclamation Re: Need Help Badly !
But before times i used to get the same speed with torrents also ! yes i did get 260KB with torrents in a private tracker
So what makes you think that torrents will be slower that HTTP anyway ?
If the seeds are surplus what would be the problem ?
Old 04-05-2011, 02:32 PM   #4 (permalink)
Excessive happiness
I am facing this everywhere. Be it @ office, home and my native. I never got higher speeds in torrents than my HTTP. That's why i presume this.
Anyway, lets wait for others to comment here.
PS Request
Old 04-05-2011, 02:41 PM   #5 (permalink)
Manc
xtremevicky's Avatar
If you put a download overnight , What is the average speed you get ?
If that is also around 130 kbps then there could be a problem.
If you like the Post , There is a Rep Button ,
If not then Understand that, There are people with different Opinions !
xtremevicky is offline   Reply With Quote
Old 04-05-2011, 03:11 PM   #6 (permalink)
TheMost's Avatar
I get around 130 -200 KB
Old 04-05-2011, 04:20 PM   #7 (permalink)
Manc
Dude , I am not asking the variation in speed . When you download stuff in utorrent then in the status bar there is Avg speed column .
Say Whe you put up 10Gb worth of data on download overnight and it completes say 4Gb. Then there must be a AVG speed . Check that .
Old 04-05-2011, 04:32 PM   #8 (permalink)
TheMost's Avatar
Talking Re: Need Help Badly !
It said 114 overnight !!!
But i get 268 with IDM !!! Same overnight ( i didn't run utor and IDM simultaneously ! :-P ) I checked running one hr each !
Old 04-05-2011, 09:21 PM   #9 (permalink)
Manc
Why dont you try some other torrent tracker / website . !
Old 04-05-2011, 09:24 PM   #10 (permalink)
dd_naik's Avatar
Depends on the seeders and leechers
Search for torrents on torrentz.com and pick the one ones with most seeds and leeches.
Do check other ppls/members comments and torrent health
That shud help you out
Glad to be of some help
I don't think u've got a port-forwarding issue.Do u?
dd_naik is offline   Reply With Quote
Old 04-05-2011, 09:31 PM   #11 (permalink)
TheMost's Avatar
Thanks a lot for a worth reply .
tnx again ...
As u told , I already use torrentz for searching and recently i downloaded Bulletstorm PC - FLT which had 2500 seeders and 1700 leechers health@100%
But the speed was 60-110 KB even overnight ,,
Any guess
Sincerely,
Old 04-05-2011, 09:39 PM   #12 (permalink)
dd_naik's Avatar
tnx again ...
Any guess
Sincerely,
Err.........I can't say much on that in this case
Actually 'm facing the problem myself
I've got MTNL's Unlimited Plan for myself for over 2 years and downloaded more than 100 gb data ..........
Suddenly the speed dropped for most unlimited plan subscribers including me and my friends.
I initially got 260 KBps be it day or night but a consitent 260KBPS throughout
Now i've( we've) been like limited to nly 50-60kBps.
Even u'd be pissed to find it takes 4 hours to download just 700MB
I'd download 4 HD Movies in four hours earlier
No response to our complaints bugs me even more.
Anyways, Luck to you.
Hope your prob settles.If it doesn't, it's an indication you dump airtel for something that sounds promising
Old 05-05-2011, 02:38 PM   #13 (permalink)
TheMost's Avatar
Actually i got what they are upto
I've been continuously using utorrent for more than 2 days and so they throttled my P2P bandwidth
Whereas in IDM the case was different and so i was not throttled
To clarify my research i did switch off my PC for 14 hrs and then checked the same torrent .....
The speed was as expected sunlight@120 KB !
I have tried forcing encryption in utorrent but it doesn't work ...
But .... I am not planning to give in !
Now using torrific temporarily ...
Any more suggestions ??
I have'nt tried port forwarding yet !
- by bhaskar
- by Soumik
