Broadband and DTHWith so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
hi,
i have mtnl broadband connection.My friend has airtel conn. of the same specifications but while downloading torrents, my speed never exceeds 60kb/s ( while downloading one torrent) while his's minimum speed is 100-120 kb/s. i feel so jealous of the fact that even after paying equal amt. of money, i get lesser speeds. please tell me some way of get higher speeds. i use windows 7 home basic.
thanks a lot in advance
I too have MTNL broadband 512 Kbps connection. And mine speed too doesn't exceed more than 60-62 KBps. It never have, and it never will be I think, unless and until I change the plan to 1 Mbps or more.
That Airtel plan you are talking about is definitely more than 512 Kbps.
But even if it isn't you have something Far more superior than that to your disposal, and for which your friend would be Jealous of you !
Its the FUP (Fair Use Policy). You can never be limited, to how much data you D/W or U/L. But Airtel does have a FUP, and sooner or later, his speeds is bound to get lower, or charges would be higher, once he crosses that limit.
So its time to
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Fellows you all forgot the basic conversion from kbps to kBps. ISPs usually use the small b which stands for bit (eg: 512 kbps, 2 mbps etc) , while download manager uses B which stands for Byte.
1 Byte= 8 bits
so 512 kbps = 512/8 = 64 kBps
So the OP is getting the correct speed as per the package.
I am using a 2 mbps ( = 256 kBps) bsnl package and the maximum download speed i am getting is only 90-100 kBps. which is half the advertised speed.
1 Byte= 8 bits
I think that clears your doubt.
that could be because of FUP
BTW did u check the SNR rate of you line...
Acer Aspire 4930G laptop- Core 2 Duo T5800 3GB ram, 320GB+LG XG1(2TB),nVIDIA 9300GS 256MB,FingerPrint Scanner,HDMI, 802.11a/b/g/Draft N Wifi
No it is not FUP. I am using a night unlimited connection.
Don't know about SNR. The telephone exchange is just 100 mtrs away. My modem got fried last week. So waiting for a new modem. Will check with the new modem.
