Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 22-04-2011, 09:42 AM   #1 (permalink)
Question DNS error
i can't open a particular website...it shows me an error msg. "DNS error occurred. Server cannot be found. The link may be broken."
i m able to open this webpage from everywhr else...but not from my pc..i connect 2 internet via micromax 3g bnsl device..when i used this device on some other pc..it gave me the same error msg..
is there something wrong with the device or BSNL ISP..??
help me out...m freakinnout....ny1 who cud suggest sumthng...??
rahulpathak is offline   Reply With Quote
Old 22-04-2011, 09:46 AM   #2 (permalink)
Default Re: DNS error
try check that site with alternate dns
go to network > settings> change ur dns to 8.8.8.8 (google)or 218.248.240.23 Secondary: 218.248.240.135.(evado) and try surfing that site again
AMD Phenom II X6 1055T ,Benq G2220HD 22 ,GIGABYTE GA-880GM-UD2H ,COOLER MASTER Elite 310 ,CORSAIR 2GB 240-Pin DDR3 X3[6GB] , FSP Saga II 500 W HD 5750 . Hyper 212+ OS :Win 7 64 bit
Rajesh345 is offline   Reply With Quote
Old 22-04-2011, 09:55 AM   #3 (permalink)
hey...i hav chngd the dns...but it is asking for some ip adress too...wat m i supposed to do there??
Old 22-04-2011, 10:00 AM   #4 (permalink)
dont change ip , leave ip address field blank
Old 22-04-2011, 10:09 AM   #5 (permalink)
its no good...again the same error msg.
"The webpage "www.abcdef.com" cannot be foundDNS error occurred. Server cannot be found. The link may be broken."
wat 2 do now...i can open other webpages...but i want ths 1.
some days back...i was able to open it....but donno wat hapnd now.
Old 22-04-2011, 10:08 PM   #6 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Ok, first check your hosts file and see if any entry is there for the site you want to access.
Can you ping the site successfully??
But still, as we don't know which site you want to access, can't say anything. As you stated that using the same data card can't open the site in other PC's too, it may be blocked from BSNL's side.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline   Reply With Quote
Old 25-04-2011, 10:27 PM   #7 (permalink)
Yeah it may be a problem with the service provider ......
Raphael is offline   Reply With Quote
- by bhaskar
- by Soumik
