Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 03-04-2011, 09:21 AM   #1 (permalink)
soumya's Avatar
Question 2 mbps connection and getting 10-15 kb/s in torrents!
I use a lot of private and public trackers. My ratios are good in each one of them. I used to get around 250-300 kB/s download speeds but all of a sudden I am getting around 10-15 kB/s. I have tried different clients but still getting the same speed. I get around 260 kB/s in Internet Download Manager even now! I am using TATA Photon +.
I blog at http://windowsxperience.wordpress.com/
soumya is offline   Reply With Quote
Old 03-04-2011, 09:58 AM   #2 (permalink)
Default Re: 2 mbps connection and getting 10-15 kb/s in torrents!
Check your speed here-
Speedtest.net - The Global Broadband Speed Test
Torrents often clow down due to peer , seeder and leecher problems...so remain calm....
Old 03-04-2011, 10:11 AM   #3 (permalink)
New Gen Guru
sujoyp's Avatar
donno about tata photon + but I am on bsnl 600 combo 2mbps and I am also getting 35-40kKBs download speed I also used to get 210KBps-220KBps
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
sujoyp is offline   Reply With Quote
Old 03-04-2011, 10:45 AM   #4 (permalink)
^^ Check if any other software is using the Internet....Game or Windows update or AV update...
Do a virus check too..
Old 03-04-2011, 11:10 AM   #5 (permalink)
Super Moderator
asingh's Avatar
Tata Photon+ gives me sh$$ DL speeds. I think they throttle.
asingh is offline   Reply With Quote
Old 03-04-2011, 11:51 AM   #6 (permalink)
soumya's Avatar
Well, I used to get around 300 kB/s even in torrents. All of a sudden it has decreased.
Old 03-04-2011, 03:55 PM   #7 (permalink)
ithehappy's Avatar
This should be the issue. I always hated Torrents for their slow speed, but once my friend told me to search for High peer, seed ones, from then I am getting 180-210 KB/Sec , but I still hate torrents as they have so less review and comments for an item
i7 950SABERTOOTH8GB RAMGTX560690II +TX650
SGS II
ithehappy is offline   Reply With Quote
Old 03-04-2011, 05:35 PM   #8 (permalink)
You may try torrent accelarator. But be carefull not to install malware.
Old 03-04-2011, 09:02 PM   #9 (permalink)
What The.... !!!
funkysourav's Avatar
you can try Newzbin as a torrent alternative
no seeding, only max speed leeching (or so i've heard)
just search for some free Newsgroup indexers and a Free Newzbin Client like HelloNZB or SabNZBD
funkysourav is offline   Reply With Quote
Old 04-04-2011, 05:57 PM   #10 (permalink)
soumya's Avatar
Seems like the same problem is happening elsewhere also :-
photon-plus-strange problem
Old 05-04-2011, 12:18 PM   #11 (permalink)
^^ Some ISP's throttle P2P traffic, so check that out.
pauldmps is offline   Reply With Quote
- by bhaskar
- by Soumik
