Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 30-11-2010, 08:51 AM   #1 (permalink)
Thumbs up Huawei 3G and Local Area Connection
I have here a working Home Network containing my PC and Laptop connected through a Cross over cable. I usually connect to internet using Huawei 3G Datacard. When the Home Network is active (Local Area Connection connected), I can't access internet using Huawei 3G. It is getting connected, but not downloading any data. Ping test at that time is showing 100% Loss. When I try disconnecting the Ethernet cable, its working fine. Please help me, I want to use internet when I'm connected to Home network using Ethernet cable.
Thanks.
Problem Solved.
It was my mistake. When I configure the network, I set both the systems as client (This computer will connect to internet using residential gateway or another computer on my network). Now I re-configured it like this:
This computer connects to the internet directly or through a network hub. Other computer on my network also connects to internet directly or through a hub.
AGENT 001 is offline   Reply With Quote
- by Anorion
- by ax3
- by sunzeal
