Now let us come to how to reduce your bill..
A Regular checkup of internet usage in the portal. Took a printed copy. If you are Home500Ul check whether night usage is charged(this is only to MP/and P3 connections not the problems with P2 connections(old NIB1)
If there is high bill don’t panic..immediately contact AOTR of your billing addresses by person, give a represent to him to reduce the bill under 'Samathan' option -IV (there are another three option but some strings attached so nobody wanted it but only wanted the option IV). There is another scheme which was previously implemented 'BVP' Best Value Plan
Unless you change your current limited plan into unlimited plan, AO might not consider your application for reduction.. because BSNL order has clearly mentioned it is to be only given once I n the lifetime of connection. So after adjustment of current bill you are still in the limited plan and they could not process another excess bill complaint..
Suppose you have used 40 GB and your total bill come under Rs 28000/ (after deducting the free usuage In your plan) than the bill will be calculated as under
1) Previous BB rental= --------------------500 (If you are in Home 500)
2) First 10 GB ------------2000
3) next 30GB(30 x100) 3000
------------------------------------------------ 5000
4) service Tax 10.3% -------------------- 567
5)
Total payable -------------------------Rs 6067
Even your past bill which are disputed and not paid by you can be reduced by using this method, only condition is if you are willing to continue in some UL plan..
I hope this post will be useful to BSNL customers as well as the readers here..
