Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 23-10-2010, 08:58 AM   #1 (permalink)
Default Plz suggest some Providers in Kolkata for 1Mbps UL
Dear All,
Currently I am using 'BB Home Combo UL 750' from BSNL.
I now plan to migrate to 1 Mbps unlimited plan.
Plz suggest me some good Broadband Service providers in Kolkata.
Thanks in advance,
Troy.
onlytanmoy is offline   Reply With Quote
Old 19-11-2010, 03:33 PM   #2 (permalink)
Default Re: Plz suggest some Providers in Kolkata for 1Mbps UL
I do not know where r u actually located, Kolkata is a vast area!
cable operators: Sify, Meghbela, Wishnet, Alliance
ISP- BSNL, Airtel, Reliance, Tata Indicom Broadband, Ortel.
dr.rdb is offline   Reply With Quote
Old 19-11-2010, 05:00 PM   #3 (permalink)
my precious
Gollum's Avatar
I think you can get a good plan at airtel. How much do you plan to spend on the unlimited budget per month
Gollum is online now   Reply With Quote
Old 20-11-2010, 11:07 AM   #4 (permalink)
@dr.rdb>> I am located at north kolkata, near Dum Dum Park.
@Gollum>> I plan to spend around 1200 per month on the 1Mbps UL plan.
Old 22-11-2010, 07:10 AM   #5 (permalink)
@tanmoy airtel is present upto dumdum in northern segment, so check if it is available.
I guess at ur place, most ISP are present.
I got good review from MEghbela/Alliance/Wishnet users from Khardah.
Old 23-11-2010, 12:19 PM   #6 (permalink)
thanks dr.rdb...i will chk out on Airtel & also the cable operators u suggested.
Old 29-11-2010, 09:35 AM   #7 (permalink)
@dr.rdb>> Is it possible to use WiFI if i go for the Wishnet Broadband service?
Old 29-11-2010, 10:40 AM   #8 (permalink)
I m not sure, but u need a Wireless Router to enable Wifi!
Old 29-11-2010, 12:30 PM   #9 (permalink)
I do have a Wireless Router (the one i am currently using with BSNL). Fine then, i will clarify this doubt with the Wishnet service provider. Thanks mate.
Old 19-12-2010, 08:21 PM   #10 (permalink)
Dude, I'd say that you should keep with a 1mbps U/L from BSNL itself, provided that you don't face freq disconnections currently.
MTNL/BSNL are the best ISPs in India. They have good customer support, and economical plans.
But, the connectivity feasibilities differ from place-to-place. So, if your current BSNL conn doesn't annoy you due to these issues, change just the plan, not the ISP altogether.
_VascoZ_ is offline   Reply With Quote
- by Anorion
- by ax3
- by sunzeal
