Go Back   Digit Technology Discussion Forum > Internet and Networking > Broadband and DTH
Broadband and DTH With so many ISPs, DTH and network providers out there, you'll need this place to discuss services, schemes, availability, share news, and even troubleshoot your problems.
Old 20-07-2010, 08:06 AM   #1 (permalink)
paroh's Avatar
Default Make broadband more stable enable interleaving
Make broadband more stable enable interleaving tested on mtnl broadband delhi adsl modem treandchip Hg520
But i am unable to make the setting permanent as when i switch of the modem and turn it back the setting are again reset
Advantage More stable line less disconnection
Disadvantage High Ping rate so bad for online gaming
My test result (DNS used 8.8.8.8)
Interleaving of (Fast mode used) ping fastmail.fm
Reply from 66.111.4.56: bytes=32 time=243ms TTL=45
Reply from 66.111.4.56: bytes=32 time=244ms TTL=45
Fast mode of (Interleaving mode used) ping fastmail.fm
Reply from 66.111.4.56: bytes=32 time=325ms TTL=49
Reply from 66.111.4.56: bytes=32 time=320ms TTL=49
Reply from 66.111.4.56: bytes=32 time=329ms TTL=49
Reply from 66.111.4.56: bytes=32 time=330ms TTL=49
Note:As you see the difference in ping rate with interleaving on and of But if ur line become more stable with interleaving on than i think u should go with interleaving on
***********For computer related Problem PM me (If want's Doeacc A Level Project PM Me )************
paroh is offline   Reply With Quote
Basic guide for the right power supply The Sorcerer Power supply / Cabinets / Mods 717 25-04-2012 03:09 AM
Turn of Interleaving achive lower ping rate and Increase SNR for stable connection paroh Broadband and DTH 7 11-05-2010 05:36 PM
Play with Registry Editor kal_21 Tutorials 16 26-12-2007 09:02 PM
Search Engine Optimization ~ Master Tutorial Retro Tutorials 25 15-07-2006 03:47 PM
Make ur computor fast and stable in 2 hours.... con_tester Tutorials 3 13-12-2005 09:43 PM
- by Anorion
- by ax3
- by sunzeal
