Results 1 to 4 of 4
  1. #1
    Jun 2005
    Default Help Sharing BSNL Dataone over the LAN
    i have got the dataone connection and have applied for Home 500 plan.
    can anybody help me to share the connection over two computers. hardware needed etc.
    do i have to switch on both the computers to access the net or only one which has the requirement will do.
  2. #2
    Mar 2005
    Right behind you...
    well as far as i know all you need is a LAN connection between two computers.
    feed your internet connection to one computer & share it over lan.
    to enable sharing u need to open your connection settings & mark the field "allow network user to share internet connection"
    u need to open both PC only to access internet over second computer(shared one)....
    alternatively u can use a switch to do same job.
    The only advantage in latter case is u need not open both computer to accesss internet
  3. #3
    Feb 2004
    Belgaum
    Follow this tutorial by raven : http://www.thinkdigit.com/forum/view...net+connection
    If its just 2 computers then you dont need a hub/switch.Since its a dataone connection incase the dataone router doesnt have ports to add more computers then you will have to get a hub/switch.Get UTP CAT5 cable of appropriate length & follow the instructions given in the tutorial & you should be just fine.
    Thats not correct.I think you meant to say ROUTER.
    A switch is just a multi-port repeater providing ports for the addition of more computers.
    www.Oobertech.net
  4. #4
    Jun 2005
    thanx digen
    'Veni, Vidi, Velcro\' - I came, I saw, I stuck around.
  1. Replies: 1
    Last Post: 07-10-2006, 05:21 AM
  2. Dataone sharing
    By digitizen in forum Software Q&A
    Last Post: 08-09-2006, 01:13 AM
  3. sharing dataone internet connection over ethernet
    By trigger in forum Broadband and DTH
    Last Post: 26-09-2005, 01:19 AM
  4. Trouble sharing DataOne connection
    By jack// ani in forum Broadband and DTH
    Last Post: 10-09-2005, 11:01 PM
  5. Dataone connection sharing
    By comrade in forum QnA (read only)
    Last Post: 12-04-2005, 09:24 PM
